MSD installed
MSD installed
Well, it finally happened. I lost all spark today. So I caved and cracked the wallet for an MSD5 and Blaster2 coil. Fairly straightforward installation.
The only problem I have now is that my (aftermarket) tach needle is bouncing around 2K RPM at idle, but it smooths out and reads accurately (I think) once true RPM reaches about 2500.
Any suggestions?
Any suggestions?
Is the tach hooked up to the tach lead on the MSD box or straight off the coil? If it is on the coil, it is reading the extra coil fires at low rpm and misinterpreting them thus giving the screwed up reading. As engine speed increases, the multi firing coil evens out and the tach gets a better signal to read. MSD provides a tach hook-up point just to eliminate this problem.
How about the tach adapter mentioned on the bottom of page 3 and shown better on page 4?
http://www.msdignition.com/pdf/5200_frm18162.pdf
punks_is_4x4
08-21-2015 01:35 PM
ripp96
07-31-2015 11:14 AM
Esibnitsud
07-30-2015 08:19 PM
