Manual Hub Problem
Manual Hub Problem
My manual hubs do not disengage when turned to the "FREE" position. The covers and dials were just redone and re-installed. The dials turn okay and the little metal balls and springs are installed. Any ideas what is wrong. Need help. Thank you.
If they worked prior to redoing them then you reassembled them improperly.
My bet is the big spring is upside down or you put them back together in "lock" and not "free".
:wabbit2:
:wabbit2:
I don't know if it's true but I have heard that if you over pack it with way WAY to much grease it would cause engagement problems? I'll duck under a table now before someone blasts me and makes me look like an idiot haha.
Ive heard the same thing !! There is a write up some where on how to rebuild them . Im sure you could find it here or maybe 4crawlers site .
Thank you guys for all of the help especially WASKILLY WABBIT. The hubs are fixed and everything works fine. The problem was the small tension spring inside the passinger side manual hub came off the engagement gear. It was never installed properly (the work was done by a Toyota Dealer-thats scary). I followed Waskilly Wabbit's instructions to the letter and fixed the hubs myself. Again, I want to thank everyone for the help and everybody should do business with Waskilly Wabbit he knows his stuff.
rushw
07-18-2015 01:46 PM
Poncho0206
07-10-2015 06:21 PM
