Installing '80 20R in my '83....couple questions
I know it will "bolt up" just curious to see if there will be any fitment issues (throttle linkage, electrical connectors, etc.) I plan on installing the power steering pump off of the blown 22R on the 20R...To those who have done this ant tips/suggestions?
power steering systems are the same , so dont bother with that unless there is an issue ?
20R is a bit of a step backwards , as there is less power ..
your best option is the put the 20R head on the 22r block ...
20r is a manual "antifreeze" plumbed choke , where the 22r is an electric choke .. so you'll have to plumb/splice in the choke . if you have the oil pressure guage , you will have to swap that
actually , I think thats it ..
Thanks guys....just trying to get all my ducks in a row before the install.....is a "heavy duty" clutch worth looking at on a dd / hunting truck? I want to put the best parts on it as possible while the engine is out...thinking on putting a header and doing away with the egr etc.....( the vacuum lines are a mess on the engine)...
rushw
07-18-2015 01:46 PM
