Pre 84 Trucks 1st gen pickups
Inconsistent running 20r
Old 02-14-2016 | 06:29 PM
Colton 0716's Avatar
Hey everyone, got a 1980 toyota pickup with the 20r and 2wd. After some work on it it was running great for a while but as the title says now it's very inconsistent when it runs. As of now, I can start it and then it will seem to run fine for a few minutes at an idle, but if I were to push the rpm up some it runs great... for about 20 seconds. Then it backfires a few times and dies, then I have trouble starting it unless I let it rest for a few minutes, then it usually starts up again and does the same thing. I'm no expert when talking about trucks but I'm stumped. I've replaced all spark plugs, spark plug wires, distributer cap, rotor, coil wire and the ignition coil itself. Still have the same problem. My buddy (who's way more technical than I am) says it could be out of time but I wouldn't think so considering that it seems to run fine until it gets to the point when it dies. Hoping some real yota experts have some suggestions, thanks!
Old 02-22-2016 | 02:45 PM
moroza's Avatar
Sounds like a fuel delivery problem. When it dies, check the fuel level in the sight glass on the carb (facing forward, roughly nickel-sized glass window).
goofybud16
03-09-2017 08:54 AM
Jota1993
12-22-2015 09:01 AM
Patricia Ringo
12-15-2015 11:53 AM
dishplayer
12-10-2015 12:58 AM
SubiKing
11-25-2015 01:50 PM
