#2861
#2862
I have yet to go run around the local U-pull-it yards and such, and hope to find some stuff there. Again, we shall see.
#2864
Tony
Also if i remember correctly, there is a guy in wendell that has lots of old yota parts
#2865
my fathers 1982 toy. with step side box (ive read that they are rare) he is the second owner he bought it in 1985 from the first owner who bought it for the dealer with the step side already on it
stock 1980 with 101000 been sitting for 17 years
#2871
[I]this picture was taken in the mid 80's. back tire's and rims off a cat 980. there is shake blocks between the springs and the frame and shake blocks in the box to keep the sides from collapsing. it's just about 6,500 pounds
#2872
Just joined, looking for resources.
Just picked up this 83 2WD, it needs a ton of TLC, i don't even know where to start. lol
(Carfax says it has 10 records, I dont have carfax, but hopefully not too bad)
First Priority
Secondary priority
First Priority
- Flasher (blinkers, hazards)
- Door Panels
- Shifter Boot
- Seats (possibly just reupholster)
Secondary priority
- Cutout rust, weld in new panels (inside bed)
- Paint
- Suspension
- Rebuild motor, Tranny, Drivetrain
#2873
First Priority
Secondary priority
First Priority
- Do they not work altogether, or are the bulbs just missing? - Door Panels
- I'd had TAP Plastics cut mine out of ABS plastic. They work. Some neoprene insulation backing them helps cut out noise - Shifter Boot
- Civic and Corolla seats are popular affordable junkyard swaps. They're fairly easy to install
Secondary priority
- Paint
- Rattle-can paint jobs work wonders! - Suspension
I have a few ideas to consider in green. Sounds like a nice project!
My two cents would be to avoid cutting panels unless you or someone you know has the resources and skills to tend to it. That's how I've humpty-dumptyed my last projects.
#2874
Hey thanks..
Yea, i'm going to use a PDF file (hopefully), & cut the sheet metal out on a plasma table.
Blinker/Hazards are fixed, was just a loose/bad connection in the column.
I did find some decent seats for a great price, but not sure i want the cloth material, im thinking all vinyl would be better, we'll see.
So i guess my next, & highest priority is now a shifter boot.. 2WD ones are hard as heck to find.!
#2876
Hey thanks..
Having grown up around a single-cab S10 with vinyl seats, I think cloth is the way to go, especially if you like wearing shorts in the summer.
#2877
It could very well be, they all kind of look the same to me.
There were a couple of kids running around town with one of those stepside beds fitted into a third-gen 2WD Toyota. It was uglier than sin, but I guess it worked.
