Help Needed: Headlight issue
I have got an '81 4x4.
problem: Driver's side Headlight is dimmer than Passenger side.
I have replaced the light, still dim, replaced the ground wire. Still dim.
Cleaned the Headlight connection with baking soda, contacts are now clean.
I have not started in to the headlight switch etc. Chilton's was not much help.
Is there a relay or something else easy that could be bad (relay etc)?
thanks,
Robb
thanks,
Robb
- http://www.4crawler.com/4x4/CheapTri...shtml#TechInfo
Roger:
Thanks for the info. If the PIAA harness did not work (it is) I was gonna be placing an order for one of yours. I had checked the fuses, relays etc and did not find the culprit. With the Hella H4's I put in it is pretty easy to tell the high/low. I do need to go through the dash lights and replace them all.
I love tracking down 25 years and who knows how many owners methods of fixing stuff. Scored a FSM for '81s off ebay. It is gonna be worth it just for the electrical
Robb
Robb
Good find on the '81 FSM, that should help a lot. At least you can find out the way it should be wired and find out what has been added/modified. And yes, putting switched power/aftermarket devices/wiring onto a switched ground system like the Toyota is tricky at best.
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
