Help Identifying Dual Carb Setup from 20R
Hello all,
I happened to acquire this side draft twin/dual weber carb setup for a 20R. It came with a valve cover, a water neck, and a block off plate. I have been searching online for pics of dual carb kits and couldn't pinpoint exactly which manifold this is. I'm thinking maybe this is some old discontinued manifold? Can anyone identify it? The valve cover looks like someone did a PCV delete and a custom breather.
I'm just wondering if anyone would be able to guide me in the right direction on what exactly I have here? It's definitely going to need some work, but I'm just trying to figure out if it's worth going through it.
Thank you for any help. Pardon my ignorance as I only have experience in fuel injected Toyotas from 22R-E onward.
The following users liked this post:
ChildrenOfBodom (10-04-2024)
It certainly is close, I guess it's the linkage kit that is throwing me off. The one I have seems to have part of the linkage casted directly into the manifold.
VwsandToys
10-05-2019 04:02 PM
