Which grille emblem
Which grille emblem
I was needing to replace my headlights and fix the grille that the PO had held together with zip ties on my ‘82 pickup so I decided it’s a good time to switch from square to round headlamps. When I tried to switch my grille emblem over I realized it doesn’t fit. Can anyone tell and show me a pic of the correct one so I can try to find one?
What I’ve got
What I need
What I’ve got
What I need
80 top
79 bottom
The following users liked this post:
SomedayJ (09-27-2020)
Another question. The PO had the grille held on by zip ties. I was looking at the Toyota parts diagram and it shows I need clips, part number 90467-13005. So how are these clips attached? Is there no screws used with these clips?
The bottom image in the diagram is my new grille.
This is the clips referenced on the diagram
This is one of the post on the grille that the clips supposedly attach to
The "T" logo in yours is more squat, shorter.
Ill measure and check clips this wknd. In the middle of a fence project
Groundpounder17 (09-27-2020)
So the top 2 pics are of the outside mounting points, which use the clip you pictured above.
the next 2 are the inside brackets which has a similar clip but has a small screw going into the pin. These center clips with the screws seem to be holding the weight of the grille.
top and bottom mirror each other, center clip has a screw and outer pins dont, on both top n bottom.
Groundpounder17 (10-03-2020)
thanks
swampedout (10-03-2020)
The following 2 users liked this post by Groundpounder17:
old87yota (10-09-2020),
swampedout (10-09-2020)
94yota05gto
08-18-2008 01:14 PM
