charging problems!!!
i thought the alternator was going out. i got it checked and it was good. the truck isnt charging the battery and wont start. so ihave to jump it. but it only lasts a few minutes and the truck dies. i got a new voltage regulator and battery, it ran for a few days with no charging problems then the charge light came back on and the same problems again???????? i dont know what the issue is with it.
i thought it was but the people at cutrate said it was good. so i will probably by a new alt. tommorow. they are only 45$ the alternator is dirty and who nows how old it is. the truck is a 79 4x4
check your fues links .. directly off the + post on the battery .. there are 2 = a double wire , and a single wire , both with green ends . give em' a tug .. if they break , the wire is burnt .
also check your ground cables .
does sound like the brushes are sticking in the alt though .. been out in the mud since it started ?
