Carb base gasket
Carb base gasket
Does anyone have the dimensions for a stock carb manifold gasket for an 81 22R? I'm installing a 32/36 Weber, I machined my own one piece adapter plate and I need the bolt pattern for the manifold side so my change over won't be held up by patterning the manifold. Any help appreciated. Fred
Bump, Anyone out there have an old gasket or phenolic riser from a stock Aisin carb of 81 vintage that they can give me a bolt pattern for? My local stealership wants $28.00 for one and I'm not even going to use it. It's for the hole spacing in my adapter plate. Help ? Fred
