82 Pickup Passenger side window issues
Okay, so when I bought my truck, I noticed the passenger side window was a bit hard to roll up or down. The other day It "Let Go" or in other words, the window stayed up, but it "rolled down". I popped off the door panel to find the previous owner had super-glued the window into the channel. What do I need to do to fix it properly.
Thanks a ton
Thanks a ton
Rowdy: I had a set of door window guts sitting around that I knew I should have saved . Dang it..With out seeing what you are facing I am guessing that the felt material or whatever they used in the channel is worn out or maybe the whole slider/gear mechanism could be shot. I had one in my old '84 that the some of the teeth towards the end were stripped. Ended up hitting the junk yard for a slider/gear set.
Sorry, I should have been more clear. The actual up/down movement is fine. The problem is how the window attaches to the channel. I think I need a new channel and the rubber strip that goes in it.
if its the channel itself, the only way out if it's rotted it to get a new one, if its expanded to far, just pop the window out, clean the channel, put the rubber and window in and clamp it back together gently
i've got a set of doors w/good glass and mechanisims nothing wrong w/the windows at all pm me if your'e intrested or e-mail me at k5mike@verizon.net theyr'e off my 83 so they should work for you. p.s. you said your'e also looking for the brake relay also. can you shoot me some a pic of it as well ?
dirtrider0129
10
06-24-2015 12:24 PM
