22r/20r Hybrid detailed info
Just curious if any one has a link to a tech write up on the 20r/22r hybrid. I currently just built one with .040 pistons, rv cam, stainless valves over sized springs, which will include a 38 weber carb. The motor is put together in the truck and now I would like to find out more about which vacuum and water lines are needed and were they need to go. What I can eliminate, and what the timing needs to be set at. Also any other ideas or tech info would be much appriciated, thanks.
TheBFA
02-15-2020 06:55 AM
buckz6319
08-05-2017 03:50 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
