Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old 12-08-2007 | 06:12 PM
slacker's Avatar
EDIT : with new INDEX
page 1 - start of frame build
page 2 - front diff build
page 3 - engine mock up
page 4 - front drv shaft , engine exhaust crossover pipe , tranny/transfer crossmember , rear disc brake mock up
page 5 - shock hoops , emergency brake mock up , front track bar , rear traction shocks , emergency cable build
page 6 - fuel sender build , Frame POR-15
page 7 - frame assembly , starter
Page 8 - wiring harness start , brake lines & fuel lines
page 9 - original Trekker tear down
page 10 - cab rust
page 11 - rocker repair
page 12 - shaved drip rails , battery tray remove , smoothie cowl
page 13 - cab repair and EPOXY primer , first full body mock up
page 14 - floor and tranny tunnel build
page 15 - first wiring harness mock up
page 16 - steering mods , battery trey , engine bay mods
page 17 - brake lines
page 18 - supercharger & FIRST start .. VID
page 19 - light works vid
page 20 - wiring
page 21 - floor install and front seat mock up , front cooling fan
page 22 - body computer box , tires , engine computer , antenna , dash build
page 23 - antenna , dash , fuel sender
page 24 - my GOLD metal
page 25 - supercharger installed and running VID
page 26 - dash mock up
page 27 - center console build
page 28 - door skins
page 29 - door skin install , new hinge pins
page 30 - cup holder , center console guages , first dash assembled pic's
page 31 - rear seat mock up
page 32 - box skin repair , tub rebuild , tub floor build
page 33 - rear tub frame build and roll bar mock up , seat hinge mock up
page 34 - rear hatch , kick panels , custom Valance
page 35 - front bumper , fiberglass door panels
page 36 - door panels , wiper motor , final tub modifications
page 37 - wire harness sauder
page 38 - cab prep for paint
page 39 - trim prep
page 40 - COLOR
page 41 - cab install , sound deadner
page 42 - wire harness install and loom , dash re- assembly , heater box clean and install
page 43 - tub PERMINENT install , rear sound deadener
page 44 - sterio wiring
page 45 - sub box build
page 46 - finally some carpet
page 47 - Body panel install and rear bumper build
page 48 - It runs , you tube vid + rear canpoy build starts
page 49 - Blocking out the old roof , and sneek peak @ interior seat fabric
page 50 - NEW fiberglass roof mould and front headliner start
page 51 - NEW fiberglass roof
page 52 - headliners
page 53 - off to paint
page 54 - outside and together , seat fabric and stripes
page 55 - yikes , broken glass . mudflaps and exhaust tip and FIRST show and shine
page 56 - vids
page 57 - more shows and vids , supercharger oil change
page 58 - paint specs
[SIZE="5"]Sorry , cant do hyperlinks , so you just have to find the page [/SIZE]
bought a few Trekkers a while back .. and now have started my own .
this one is going to be a "some what" stock restoration .. but with a few "extras" .
so here's where I'm starting .
don't mind the dust .. it's been sitting inside my shop for a while now .
there is one small rust hole on The right side .. front spring hanger , inside box steel .. you can see it in the pic .. it's so minor , I'm just going to weld in a patch .
so a little work today ... got onto the frame repair .
got the little plates/patches welded in .. It really wasnt that bad at all , the main / worse dammage was from me hitting with a hammer it trying to find the rust .. I really didnt see any point in doing "fish plates" .. as there (in my opinion) was NO structural strength loss . Other side is perfect .
and done ..
also started "prepping" the frame for the POR-15 treatment.
Old 12-08-2007 | 06:24 PM
infiltrator's Avatar
dang, you got alot of work ahead of you lol. make it nice :]
Old 12-08-2007 | 06:27 PM
pitpatt's Avatar
looks good so far! congrats on finding a frame off a truck that old in that good of shape up there in the snowy regions!
Old 12-08-2007 | 06:28 PM
phildelfino's Avatar
Good to see you doing something for yourself instead of building one and shipping it elsewhere. I'm sure it will be a NICE build and the extras worth the trouble. What is POR-15 by the way?
Old 12-08-2007 | 06:34 PM
EWAYota's Avatar
Por-15 is a rust preventative paint.
Looking forward to watching the build.
Old 12-08-2007 | 06:42 PM
slacker's Avatar
thanks guys ..
yep .. por-15 is a coating .. prevents O2 from contacting the steel .
stops rust , and seals the metal . http://www.por15.com/
I have used it before . and it's great stuff.
Old 12-08-2007 | 07:03 PM
rowdy235's Avatar
well good luck on your new project.
Can't really think of a better example of building from the ground up
Old 12-09-2007 | 05:04 PM
slacker's Avatar
Originally Posted by ocdropzone
So I take it one of the 'extras' you are talking about is this thingy you found:
that would be cool for mine if you decide it won't fit under your hood
something like that
Old 12-11-2007 | 04:12 PM
slacker's Avatar
so got the top side done (cleaned) , flipped it over and started on the bottom side .
Old 01-15-2008 | 05:09 PM
slacker's Avatar
so , now that the "LONG box" Trekker is gone , I can now start building mine ..
I bought a "parts truck" a while back .. for a couple of reasons .. I needed a long box frame for the dimentions of the long box Trekker .. I needed a front clip .. I needed lots of small parts and pieces for my trekker build , so I bought a whole truck .
so Yesterday .. I started to tear it apart .
box had been removed previously , and I had cut a hole in the back of the cab for the "long box Trekker" I built ...
Now that that project is all done (for me anyway) It was time to get to work on my project .
I sold the long box frame .. and I need alot of the pieces for my trekker .. so time to strip it .
lots of work yesterday , cut the roof off , and rockers , and cab corners .. I'm going to make some replacements so i wanted to keep them . got the engine bay mostly stripped , and engine out .
and here is where I started this morning ..
and finally the cab off ..
frame stripped ..
and diffs ready to build .
and finally my front clip .
Old 01-15-2008 | 05:59 PM
idayota's Avatar
looks good...can't wait to see what comes of this.
Old 01-16-2008 | 07:30 AM
slacker's Avatar
My wife saw me looking at your post and said,"No way are you taking your truck down that far!"
Gonna be a nice job from the ground up.. Is that 2nd Gen front clip for your hot rod project?
Bumper brackets are yours when you want them...will get a shipping price for you next week...and can send them when ever you need'em
hahaha ... she can read your mind ?
front clip is for my Trekker .. it was punched on the front right side .. bent the frame and dammaged the inner wheel house I wanted to keep that cab , because it has the OE moon roof .. so I will repace the front clip .
Thanks , freight quote would be great ..
Old 01-16-2008 | 07:31 AM
slacker's Avatar
thanks bro ! its going to be a slow one though .
Old 01-16-2008 | 01:53 PM
idayota's Avatar
hey, i got nowhere better to be!
Old 01-16-2008 | 02:07 PM
kylextrisler's Avatar
goin from the ground up! thats gonna be a sweet build, i'm lookin forward to it aswell!
Old 01-20-2008 | 02:16 PM
slacker's Avatar
so the supercharger is GONE .. he sold it out from under me ! ohh well , I wasnt overly excited about it anyways , I was pretty leary about buying it .
so .. I'm thinkin' maybe 3.4L and supercharge it , or maybe V8 .. kinda like the idea of staying toyota .. any ideas , anyone know of any 3.4 installs into 79-83 vintage ?
Old 01-20-2008 | 02:32 PM
881stGenRunner's Avatar
First off, i love your work, im always lurking in your build threads. Im sure you have heard it before, but i always enjoy hearing it in my own threads...
Im pretty sure ORS has done it before, check out their website or shoot them a pm/email. I really like the idea of the 3.4, go for it.
EDIT: *subscribing*
Old 01-20-2008 | 04:06 PM
slacker's Avatar
thanks bro ! ....
I did check out there site , and there is nothing there for the 79-83's .. only 84 and up ..
I did read a whole lot though .
Old 01-20-2008 | 04:42 PM
check out this thread. I remember somewhere in it they mention the swap into earlier trucks - https://www.yotatech.com/forums/f160...runner-122396/
Old 01-20-2008 | 05:05 PM
slacker's Avatar
tks ..
ok , so more reading .. and I sent an email ..
