FS[PacNorWest]: 1994 4Runner Auto SAS Project $2500 **SOLD**
Link to Build Thread: https://www.yotatech.com/forums/f199...l#post52473059
$2500 As it sits
Located in the Beaverton, Oregon Area
3.0 V6, A340 Auto, approximately 206K on the motor, I have paperwork somewhere for the headgaskets being done at around 190k
I am burned out on my 1994 4Runner project. Started a dual transfer case install using an Inchworm gear adapter behind the A340H automatic in January of 2019.
Had it all together, had no reverse and barely moved forward. Tried swapping valvebody from another A340, still no luck
I was going to swap another A340h into the truck but I am just burned out on this thing. that transmission and a toyota factory A340 service manual is included
Front end stuff:
SAS using an 81 Front axle
Low Range Off Road low profile front spring hanger
4" Trail-Gear front springs
Trail-gear dirty 30's front axles
5.29's with an Aussie locker
Trail-Gear Trunnion Eliminator
ARB studs in the steering arms
Front Diff Armor/Truss
Trail Gear High Steer
Front axle was rebuilt when the truck was SAS'ed at Northwest Toys LLC about 5-6 years ago, one side has developed a small leak
Rear suspension:
1997 FZJ80 rear coils with a spacer
5.29'sV-6 rear third, rebuilt with a full install kit(bearings etc) approx 2,000 miles on rebuild
5-BFG 35x12.5x15 KM2 MT's - approximately 6K miles
91 4Runner Rear swing out tire mount modified to clear the rear bumper
Armor:
Front T-G winch bumper with a front hoop added to it.
Rear T-G bumper modified to work with the rear 4Runner swing out tire mount
4Xinnovation sliders with kick out
21 spline dual cases with RADesigns triple sticks
Custom ordered Bud Built Crossmember with extended skid plate to work with the automatic
Interior:
- front seats are out of a 2006 Civic -
- hybrid locking center console made using a Tuffy Samurai and Toyota factory console
Exterior:
- an OK job of roll-on Desert Sand Monstaliner
- Jungle Fender Flares
- Roof rack mounts were extended about 24" (8020 roof rack i built is not included)
- Snorkel right now is for looks, it was one bought off ebay, will include the parts to finish the install, it was one purchased off either ebay or amazon
Spares:
-Top shift transfer case
-rear axle housing (i was going to convert to rear leafs)
-full set of doors with glass (green with tan door panels)
-L/R front fenders (green)
-set of rear window glass
-misc parts like headlight housings/mirrors
I am keeping the roof rack I made, the winch and exterior lighting.
I will update this post in a day or so with some pictures.
Truck is sold as is, unable to start the motor since the valve body is not currently in the transmission.
Sold as a rolling project
$2500 As it sits
Front end stuff:
Rear suspension:
Armor:
Interior:
Exterior:
Spares:
oldbilwaulke
01-26-2013 08:12 PM
Dexter350k
07-21-2012 05:16 AM
DIRTCO
05-21-2011 07:05 PM
boltman
11-01-2003 05:36 PM
