Product Reviews Post your reviews on automotive and expedition-camping gear here
Camo4u Camo Wraps
Old 11-02-2012 | 11:13 AM
5wider's Avatar
Camo4u Camo Wraps
Does anyone have experience working with camo vinyl wraps like these:
http://www.camo4u.com
Old 05-09-2013 | 01:01 PM
5wider's Avatar
anyone...
Old 09-27-2013 | 12:56 PM
5wider's Avatar
Old 10-11-2013 | 05:35 PM
peek4060's Avatar
I'd like some info on this as well.
Anyone?
Old 12-24-2013 | 08:55 AM
5wider's Avatar
checking one more time
Old 12-24-2013 | 09:23 AM
blake.nemitz's Avatar
I do but not the camo. i did wood grain and black. the stuff is easty to work with but a heat gun is your friend as well as keeping clean surfaces. the black vinyl is so thin the dash texture comes through
Old 12-24-2013 | 09:24 AM
plus a very sharp knife or if you can get your hands on a scalpel those are the best for trimming the hard areas like the speaker vents and edges. also it is hard to trim a strait line so i used pinstripe tape dropped on the ground to make the backing not so sticky and used that as a guide.
Old 12-24-2013 | 09:28 AM
For the money Hydrographing would be a lot easier, look better, and is less than 100 bucks for a diy kit and excellent results can be achieved. going to hydro dip my dash in my first gen in camo because after 5 years the vinyl looks like poop and is peeling by the heater vents. check out you tube vids on it. easier process and way cleaner
Old 02-07-2014 | 02:39 PM
5wider's Avatar
Is this the DIY Dip kits you are talking about? www.camodipkit.com
Old 02-08-2014 | 08:20 AM
Yes. I bought one and will post pics of some stuff i dipped.
Old 02-08-2014 | 08:26 AM
my gun holster.
turn signal on my dirtbike
Old 02-08-2014 | 08:32 AM
its finished in a low gloss clear that came in the kit. a high gloss would look better i think.
Im about to attempt to do the valve cover for my new project. 2jzgte + 86 4runner swap.
thats all ive got. if you get the kit practice a lot and watch the you tube vids for techniques. after a few tries it gets easier. lots of variables. ill post the valve cover when i do it.
Old 03-19-2014 | 02:18 PM
5wider's Avatar
awesome pics... which camo pattern is that? I see several at www.camodipkit.com that look similar to that...
Old 04-29-2014 | 12:56 PM
5wider's Avatar
what pattern of camo dip kit did you go with? I really like it...
Old 04-29-2014 | 01:00 PM
http://www.camodipkit.com/patterns-camo.htm
toward the bottom MC-841.
Old 06-24-2014 | 12:09 PM
5wider's Avatar
awesome!!!
Old 02-12-2015 | 10:10 AM
5wider's Avatar
I did finally get a camo wrap from Camo4u and did my truck - turned out AWESOME....
Old 04-19-2015 | 12:20 PM
sphealy's Avatar
Pics?
Old 07-11-2016 | 06:20 PM
5wider's Avatar
Originally Posted by sphealy
Pics?
How do you post pics
