Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
how to run power wire from battery to amp?
Old 06-12-2007 | 07:51 PM
NinjaWa's Avatar
i'm planning to install a stereo system in my 93 pickup and was wondering how to run the power wire from battery to amp. is there a hole on the firewall or anything that i can run it through. i tried searching but couldn't find anything on it. thanks in advance...
Old 06-12-2007 | 08:05 PM
Elton's Avatar
pull the carpet back on the pass side look around should fine a spot
Old 06-12-2007 | 08:06 PM
881stGenRunner's Avatar
just find a hole in the back of the firewall where your feet go and look for any rubber gromet to put it through.
Old 06-12-2007 | 09:06 PM
nieuwendyk-25's Avatar
or drill your own and put a grommet in it....you can get them at any hardware store. Mine is the red wire. Sorry for the bad focus.
Old 06-14-2007 | 12:49 PM
NinjaWa's Avatar
thanks for all the responses, i guess i'll give em a try.
Old 06-15-2007 | 01:02 AM
mehret's Avatar
In my truck, there was an opening on the passenger side. If you aren't that fortunate, what I've done in the past with other vehicles is locate a rubber plug in the firewall that may be covering a hole for an optional accessory and cut an X in it with a utility knife. You can then run the wire through that and maybe seal it up with RTV or something.
Old 06-15-2007 | 07:20 AM
Greg_Canada's Avatar
I ran a 4 gauge wire through the firewall grommet, but now since i've upgraded to 0 gauge, i drilled a hole beside the firewall grommet and ran the wire like nieuwendyk-25
Old 07-06-2007 | 03:27 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
^^^ Look at the bigger rubber grommet on that pic. There should be one on your passenger side. In my truck I just took an "all", pokey thing, and poked a very small hole under the big wire and then forced my 8 gauge through the really small hole. Being such a large wire for such a small hole, it was very waterproof. If your running thicker wire then you can make a bigger hole if you have to, or use a knife and make an X like the other guy said.
If you have not done it yet.
God's Bounty Hunter
07-08-2015 12:54 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
rbravo1
06-29-2015 01:34 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: how to run power wire from battery to amp?
