99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Best Brake Rotors?
Old 07-11-2005 | 10:43 AM
black02's Avatar
Best Brake Rotors?
Does anybody have an opinion on what the best brake rotors are? I have a shimmy when braking, and figured I'd get them turned, but the shop said their book says they're Non-Servicable. He offered me 2 choices - $50 apiece rotors or $95 apiece rotors, but had no idea what the difference was. Stock Toyota ones are $100 apiece, but are they any better than the $50 ones at discount places? Also, are slotted ones a good idea, or do they just eat pads up quickly? I just put new Toyota pads on.
BTW I have an 02 Tundra TRD Limited 4x4 Access Cab. I don't do much towing, but would like to someday. Mostly city driving right now.
Thanks!
Old 07-11-2005 | 11:36 AM
jimbo74's Avatar
if you buy new rotors its a good idea to replace the pads at the same time... as the warped rotors can wear a pattern into the new pads and cuase other problems if reused on the new rotors later...
look towards tirerack.com i got brembo blanks from them and have put about 500 miles on them and they are performing great....
Old 07-21-2005 | 12:34 PM
Any good vented (either drilled, or cut, or both) rotors out there? Mine are slightly warped from towing a heavy trailer w/o brakes connected, and I'd like something capable of dissipating that kind of heat in the future.
Old 07-21-2005 | 01:44 PM
PO2SIMS's Avatar
I just replaced mine w/ LC Engineering drilled and slotted rotors for $45 plus EBC pads. Stopping powers has increased.
Old 07-21-2005 | 09:23 PM
rngrchad's Avatar
The best rotors: OEM. Original equipment buy them at a Toyota dealership.
Old 07-21-2005 | 10:20 PM
jimbo74's Avatar
i got brembo oem replacements... over 1000 miles on them and no complaints... jsut using standard replacement pads.... raybestos pg plus with noise solution
Old 07-22-2005 | 04:23 AM
rngrchad's Avatar
Yes, stock is much better. You may see 2 to 4 times of longer life out of OEM replacement rotors when matched w/ OEM replacement pads. Seems funny but Toyota OEM is, for the most part, about the best investment you can make when doing preventive maintence.
Old 07-22-2005 | 05:54 AM
cubuff4runner's Avatar
Brembo rotors work great for me.
Old 07-22-2005 | 06:30 AM
midiwall's Avatar
For my 4th set of rotors in 9 years, and 3rd set in the last 18 months, I went to Brembo slotted. They're SOOO much better than anything else I've had on there... OEM, Napa...
I agree with Jim, replace the pads as well.
Old 07-22-2005 | 06:40 AM
Lance's Avatar
Brembos rotors way better than stock, and PF pads. Change the pads when you change the rotors.
jashoeuh
11-26-2017 07:01 AM
Leviticus6432
11-20-2015 05:06 PM
romex1
08-10-2015 06:21 PM
ty1er
08-01-2015 11:53 PM
ahriman
08-01-2015 10:38 AM
Quick Reply: Best Brake Rotors?
