96-02 4Runner Rear Plate Bumper
Protecting your rear end is just as important as the rest of the truck and the good people at 4x Innovations know that! They have engineered this rear bumper to provide you the comfort and peace of mind you need while off the beaten path. Starting with proven 3/8” high grade steel mounting plates this bumper has the strongest mounts available. The main bumper is high grade 3/16” steel plate. Two ½” thick recovery shackle mounts are interlocked into the main bumper and fully welded directly to the main mounting plates. We know your departure angle is important to you, and this rear bumper is designed with a great low profile for maximum clearance.
If all that isn’t enough, we saved the best for last. All bumpers come with an integrated DOT rated receiver hitch. Our receiver hitch has been engineered and tested to exceed the SAE testing standards for a class 3 hitch (500lbs tongue load, 5000lb trailer weight).
Bumpers are fabricated in Wisconsin from American Made Steel. Bumpers bolt directly to the frame using factory bumper mounting holes and hardware. Bumpers ship bare steel to save you big money on handling and shipping fees!
Order yours today for just $711!
Also you can add a swing out spare tire carrier for just $399 for the base tire carrier with mount. Add to that 1 or 2 NATO Jerry Can Mounts for the discounted price of $128 each.
Vargntucson
07-04-2015 12:15 PM
