Old 03-21-2016, 12:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Brake Guides
Print Wikipost
Tundra Brake Upgrade FAQ
Old 08-10-2011 | 05:17 AM
waskillywabbit's Avatar
Restored:
Share your good Tundra brake upgrade info and links here.
If you have questions, read the links below. It's ALL there.
Ritzy4Runner's
https://www.yotatech.com/forums/f2/0...runner-146160/
Rock Slide's
https://www.yotatech.com/forums/f2/t...ss-red-133294/
Old 08-10-2011 | 12:07 PM
sdsurfer's Avatar
yes both great write ups. also, ebay has great drilled slotted rotors, tundra, for 100 shipped USA. good luck brake upgraders! best thing ive done!
Old 08-11-2011 | 01:18 AM
BigFishAllDay's Avatar
I just got done installing the 13WL's (231mm setup) on my 2001 4Runner... I put together a pretty exhaustive write-up on it, including alot of hard to find specs & info on the calipers & rotors.
http://www.toyota-4runner.org/3rd-ge...rs-rotors.html
Old 08-14-2011 | 04:15 PM
space-junk's Avatar
i assume that the tacomas would be the exact same?
Old 08-15-2011 | 10:18 AM
As far as I know, yes, that is correct.
Old 10-10-2011 | 09:55 AM
Land Pirates Off Roa's Avatar
We place 2000 to 2006 Tundra brakes on 98 4-Runners... Just need to clearance the caliper to wheel just a bit. =-) Brembo rotors help out if you want slotted... =-)
Old 11-06-2011 | 07:01 PM
Sully99's Avatar
Just did mine thanks to BigFishAll Day... it was a piece of cake. Thanks
Old 12-27-2011 | 07:25 AM
terminator's Avatar
I just read the thread on the write up and I always wondered how the backing plate needed to be cut, the pics cleared it right up!
NOW, I also see you had a wheel clearance issue with your spare. Is it the steel factory spare or aftermarket wheel? I have the 16X8 LC wheels and would like to know if anybody has had any fitment issues with the 231mm brakes and the LC wheels.
Old 12-27-2011 | 08:46 AM
Yes!!! So sorry for not mentioning that!!! It is a GREAT write up!!! Awesome photos to boot!
Old 01-02-2012 | 07:20 AM
80 series LC wheels will not clear the 231mm caliper. You will have to do some grinding on either the caliper or the wheel, OR run wheel spacers on the front in order to get the proper clearance.
The spare that I used to test fit was the factory steel spare common to all 3rd gen 4Runners. I have since found an aftermarket wheel to use as a spare. Another solution would be to purchase a 1/4" wheel spacer (the type that slip over the studs), keep it in the truck at all times, and use it temporarily when installing the spare up front.
Old 01-02-2012 | 07:25 AM
terminator's Avatar
My spare is a LC wheel too. Hmm, don't know how much grinding I'd need to do to the caliper by chance do you?
Old 02-29-2012 | 06:55 AM
aowRS's Avatar
Here's my recent 231mm install:
https://www.yotatech.com/forums/f2/m...pgrade-249984/
Andreas
Old 04-24-2012 | 10:44 PM
SharpStick's Avatar
More big brake action on Off-Road.com
I love this swap. So many upsides, you can't not.
http://www.off-road.com/trucks-4x4/p...oject1620.html
This was my full coverage of the 231mm swap, including how to clearance the 16-inch split-spoke wheels.
STICK
Old 06-21-2012 | 08:25 AM
j-man's Avatar
One of the nicest writeups ive seen. Thx....im doing this to my 99 4runner & my 01 Tacoma
Old 06-28-2012 | 06:25 AM
terminator's Avatar
What wheels/rims are you all running with the 231mm calipers and are you running any spacers? Pics would be great along with details.
Old 06-28-2012 | 06:31 AM
aowRS's Avatar
Standard-issue 2002 Toyota 16" alloys. No spacers.
Andreas
Old 06-28-2012 | 06:53 AM
terminator's Avatar
No kidding, did you have to clearance the calipers any?
Andreas
Old 06-28-2012 | 07:13 AM
aowRS's Avatar
None whatsoever - click on the link in my signature.
Andreas
Old 06-28-2012 | 10:14 AM
terminator's Avatar
I wonder what the difference is on the LC80 wheels then. That's what I have so I guess if I go 231's then I'll need spacers. Any suggestions on spacers? I have 0 experience with them.
Old 06-28-2012 | 10:41 AM
I just put some 1.5" wide on my 95 to clear the center caps, it's a 2WD. Nothing to them.
:wabbit2:
Quick Reply: Tundra Brake Upgrade FAQ
