Tacoma front shock/strut bushings
Old 06-04-2009 | 03:03 PM
bain's Avatar
Hi, I have a 98 Tacoma 4x4 and on the front shock/struts, I'm needing the bushings that are on the bottom end of the shock that is bolted to the lower control arm. Anyone know where I can find these.. Thanks
Old 06-04-2009 | 05:19 PM
Bighead's Avatar
Junkyard/Pick-n-Pull.
Old 06-04-2009 | 05:21 PM
Savage1016's Avatar
the lower bushings are pressed in but depending on the brand of shock you may not be able to buy just the bushing. i know in the autozone cheapies the lower bushing is not replaceable you have to get a whole new strut assembly. i believe if you have bilstein fronts especially the 5125 series there are lower bushings available but i am not sure where to get them
Old 06-05-2009 | 02:43 PM
bain's Avatar
well 10 minutes of explaning and $45 later I walked out of the Toyota dealership with two little bushings..
Old 11-29-2009 | 06:20 PM
98srx6's Avatar
Do you happen to have the part number of the bushings that they gave you?
Old 11-29-2009 | 11:37 PM
KZN185W's Avatar
Flying91
45
04-11-2024 04:39 PM
glowz825
01-25-2022 09:28 AM
94whiterunner
07-12-2015 07:15 PM
TokyoD23
07-12-2015 06:01 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Tacoma front shock/strut bushings
