Stereo install on Double DIN 2002 4runner
Old 06-02-2003 | 10:20 AM
Yotabozo's Avatar
This is my first post --- woohoo. Question is simple, answer may not be.
I have a stock 2002 4runner Stereo/CD/Cassette in Double DIN size. However, I'd like to pull it out and replace it with a regular MP3 player (single DIN).
Do I need some kind of kit (i.e. what happens to the empty space that will now appear below)?
Any step by step instructions on how to install and what kits are needed would be appreciated.
By the way, this forum rocks....I've done some mods, but wife is limiting the rest.
Old 06-02-2003 | 11:54 AM
sabre's Avatar
I have a jvc-kdsh99 in place of my double DIN. I had it installed on my '01 after a few months of owning it. The installer used a mounting bracket that had an empty compartment under the deck. You could put the empty compartment on the top and the deck on the bottom but I dont think it looks as good. Its a good compartment to throw small stuff in but nothing seems to stay there while driving.
I know there is a factory amp used by your deck now that you will have to remove.
Old 06-02-2003 | 11:55 AM
Andrey's Avatar
You will need two items to install aftermarket stereo:
1. Toyota wiring harness
2. Toyota pocket
The wiring harness will let you connect your MP3 deck to the Toyota amplifier and speakers, and Toyota pocket will fill in the empty space below your new deck.
And, by the way, welcome to the Yotatech!
-- Andrey
Old 06-02-2003 | 04:53 PM
Yotabozo's Avatar
Thanks guys. Is there a specific mounting bracket/pocket made for 3rd gen 4runners? I don't know where to start to get one of these. I guess besides this unique part and the wiring harness, everything else should install as usual in a single DIN car.
Old 06-02-2003 | 06:52 PM
Andrey's Avatar
That is correct, no special adapters needed. Just the Toyota pocket which you can buy at either BestBuy or CircuitCity and the wiring harness. Everything else mounts just right in.
-- Andrey
Old 06-02-2003 | 07:38 PM
Yotabozo's Avatar
Thanks Andrey...sounds easy enough...I'll post some pictures when done. Thanks again.
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Stereo install on Double DIN 2002 4runner
