Old 02-10-2016, 09:44 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
RPM/Speed/Tire Size ratio calculator??
Old 08-18-2003 | 06:31 PM
ravencr's Avatar
I've had a magazine before tell me how to calculate the differences in RPM and speed based on tire size, and now that I'm running larger tires, I was wondering what my actual speed is versus my indicated speed on the speedometer. Anyone know the calculation? Also, is there a standard gear ratio on a 1997 4runner? Also, how can I find out my gear ratios too? I'm pretty sure all those items are needed, right?
Chris
Old 08-18-2003 | 06:58 PM
4RUNR's Avatar
Guest
Very simply...
MPH = (((RPM*(1/(GEAR RATIO))*(TIRE CIRCUMFERENCE))*60)/63360)/4
Old 08-18-2003 | 07:21 PM
ravencr's Avatar
Thanks man! How do I calculate gear ratio? Is this the final drive ratio of the tranny or my rear end ratio, or some combination of both?
Chris
Old 08-18-2003 | 07:38 PM
4RUNR's Avatar
Guest
Just get the correct ratio from ... http://www.top4runners.com/ja/runhist/1998specs.html
example:
Ratios 1st.........2.804
2nd.........1.531
3rd.........1.000
4th.........0.705
That number is the gear ratio. The formula is not from anywhere though, I just thought it up But I'm pretty sure it works.
Old 08-18-2003 | 10:07 PM
Mad Chemist's Avatar
https://www.yotatech.com/attachment....&postid=108827
The picture above is for the most common upgrade to 285's, here is the link below to do it for yourself:
http://www.csgnetwork.com/lttrucktireinfocalc.html
Old 08-19-2003 | 03:16 AM
ravencr's Avatar
Thanks everyone for the help!
Chris
Old 08-19-2003 | 04:43 AM
Victor's Avatar
https://www.yotatech.com/~corey/portal/portal.htm
scroll down to tire and gear calculator. It doesn't list the speed changes to the speedometer as well but it does give you gearing info.
Old 08-19-2003 | 05:01 AM
Gadget's Avatar
If you do not have the factory locker and you have an auto you most likely have 4.1:1 diff gears like me.
If you are going to the 285/75R16 tires and want to regear to restore like stock gears then 4.56:1 gears will get you the closest. That will get you 100 RPM more then stock at like 60-65 MPH.
I can't remember off the top of my head right now, but I think the next size down is like 200 RPM under stock.
I am still on the fence about regearing, but if I do, I am going 4.56.
If you are running the same tires as I am your speedo is going to run about 10% low with stock gears. You can hook up with me and I will use a RADAR set and you can make a correction card up for your dash to know you true speed, or you can get one of those speed correction gadget. www.frankenTaco.com has one on his site.
Gadget
www.GadgetOnline.com
Old 08-19-2003 | 01:04 PM
ravencr's Avatar
Thanks guys,
I have an auto with the rear e-locker, so anyone know that rear end ratio?
Chris
Old 08-19-2003 | 01:07 PM
mtnfreak's Avatar
For simply figuring the difference between tire sizes (no other changes) go HERE .
This Link may be of some help in determining your ratio.
Old 08-19-2003 | 06:36 PM
ravencr's Avatar
Thanks everyone for the help! That's exactly the information I was looking for.
Chris
smilen724
13
11-08-2015 04:11 PM
Gravel Maker
RuffStuff
10-04-2015 10:26 AM
oldblue
09-28-2015 04:07 PM
Odin
09-26-2015 06:56 PM
Gravel Maker
RuffStuff
09-08-2015 05:46 AM
Quick Reply: RPM/Speed/Tire Size ratio calculator??
