Last edit by: IB Advertising
- Toyota Tacoma 4Runner Modificaton Increase Towing Capacity<br>Overview of popular modficatons to customize your Tacoma.
mods to increase towing power for a tacoma...please help!
i need to know some mods that will help increase power when im towing, its a 98 tacoma with 32's and some lift. i need to be able to tow at least 5000 pounds without problems, i have done the deckplate and i have done my version of the isr mod, what next? i may do the ect mod next, dont know if i want to mess with that or not though! im thinking, new cat back exhuast? how much will that help? thanks a bunch
wade
wade
I regularly tow 9000 lbs with my sc tacoma-- not by choice mind you. towing a heavy load sucks with a supercharger because you have to use the low end torque and the engine doesn't like it and starts pinging after a few seconds--there is no way to stop this, I have all the fuel mods--headers, intake, exhaust, injectors, safc and anything else and it still pings when towing. it doesnt ping when driving around normally. if i had a choice, id get a tundra for towing. small engines cant tow anything-- i dont care what anyone says--unless its like 2000lbs, which is nothing. for doing real work, get a v-8
T
T
Originally posted by Duffdog
I...small engines cant tow anything-- i dont care what anyone says--unless its like 2000lbs, which is nothing. for doing real work, get a v-8
T
T
Originally posted by ewarnerusa
100% agreement. Get a 7.3L Power Stroke turbo diesel V8 like our work truck...
Originally posted by KING
....Or a 6.0L POWER STROKE TURBO DIESEL with 615 FT. LBS of TORQUE @ 2200RPM!
ahhhh.....here's my answer. "A new 6.0-liter Power Stroke diesel engine is available for 2003 models that’s cleaner, more efficient, and more powerful than the outgoing 7.3-liter diesel. Though smaller in displacement, the new 6.0-liter turbo-diesel V8 is rated 550 lbs.-ft. of torque at 2000 rpm. The outgoing 7.3-liter Power Stroke turbo-diesel, available on early 2003 models, offered up to 525 lbs.-ft. at just 1600 rpm. The 6.0-liter engine produces 325 hp at 3300 rpm, compared with the 7.3-liter’s max 275 hp at 2800. "
Wade...
I hope you don't plan on towing for a distance. You will kill the Taco.
The Tacoma is only rated to tow 5,000 lbs. But you need to look at the specs.
That 5,000 lb capacity is with a bone stock Tacoma with one 150 lb person, 1/2 tank of gas, no radio, no air no nothing.
When you add stuff to the Tacoma like gas ( 1 gallon of gas = 5.8 to 6.5 lbs) radio, and air you need to subtract these numbers from the 5,000 lb tow rating. Next thing you know, you have added 500 lbs of weight and reduced your towing capacity to 4,500 lbs.
I own a '97 GMC Yukon with a 5.7 liter V8 that weighs around 6,000 lbs. It has a towing capacity of 6,500 lbs.
I tow a 23', 5,000+ lb trailer. I have trouble in the mountain passes with the big V8 and sometimes in strong head winds it slows me down a bit.
Look at what my trailer does to the rear of my Yukon with only a 300 lb tongue
This is the reason i sold my '97 4runner and purchased the GMC.
If you are planning to tow often then i highly recomend going to a RV forum and read over some of the posts there. So often people purchase a travel trailer thinking there mimivan or small pickup will tow 5,000 lbs because that is what the manufacturer said.
You can tow that much if you are on a flat ground going short distance, but if you plan on adventuring farther then you might want to look at a different set up.
If you want any other info let me know. Just don't want to see you burn up your rig because of some bad advertisement.
Later.
Later.
vanion2
07-29-2015 06:17 PM
Jeffreynmandy
07-18-2015 08:26 AM
