Old 02-09-2016, 10:10 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Map light removal????
Old 11-04-2002 | 04:51 PM
CBDenver's Avatar
All,
Does anyone know the easiest way to get the covers or unit off to change out the (2) map lights by the rear view mirror?
FYI the 1997 map lights are the same as the dome light and rear cargo area according to my manual and looking through the clear spot in them.
I didn't want to mess them up, so any advice in getting the things off is appreciated!
Thanks,
Chris
Old 11-05-2002 | 06:31 AM
CBDenver's Avatar
**Bump**
Anyone know how to get those covers off on the map lights?
Thanks,
CB
Old 11-05-2002 | 03:38 PM
sleepy1405's Avatar
I think mine is different from yours but I just used a flat head phillips screwdriver to pry the lenses out, although the manual said the bulbs are supposed to be the T6 bulbs the same as the other dome lights, they weren't
Old 01-10-2003 | 12:31 PM
trystjr's Avatar
I too wouldlike to know how to replace the map lights, I have a 93 4runner and Itook a look at it this morning and Iremoved a small covering, but that was all that I could remove, I also saw 2 screws that might be possible to remove but it is at an extreme angle and damage woud be caused if I remove them any help ?????????
Old 01-10-2003 | 12:38 PM
ravencr's Avatar
Just did it on my 1998 a few minutes ago.
Take a flat head screwdriver and pop off the center piece. It's small and it will pop right out. Then you'll see those little screws you can't get to, but that has nothing to do with it. Just take the screwdrive again, and pry off the big cover, and it will pop right off as soon as you stick the screwdriver up in there. It's that easy.
By the way the Rabrig R135 12v8w bulb for the door light does not work for the 1998. It's a totally different bulb, which I should have checked before I bought it. Does anyone know which bulb I will need? It looks almost the same as the PIAA's, but it is slightly shorter and has crimped ends on it. Anyone know what aftermarket bulb works in this or how I can determine what to get?
Chris
Old 01-10-2003 | 12:47 PM
trystjr's Avatar
right on, It worked thought it would be tougher but it worked, thanx man
Old 01-10-2003 | 12:53 PM
ravencr's Avatar
No problem! Glad I could help, because so many people have helped me on this forum.
Chris
Old 01-11-2003 | 07:50 AM
UKMyers's Avatar
You were almost there. Pop off the small cover and then just pry the big piece loose. The whole thing comes off pretty easily just takes a little force.
Old 01-12-2003 | 05:25 PM
ravencr's Avatar
That's what I said, wasn't it UKMeyers?? Just messing!
Chris
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
B1gR3d
08-01-2015 10:10 PM
Esibnitsud
07-30-2015 08:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: Map light removal????
