How to replace rear view mirror?
Old 10-22-2005 | 08:38 AM
apco25's Avatar
All,
here is a simple question : how do I replace the rear view mirror? Moreover how do I remove it? There are two screws, but cannot get the mirror out. I have a 2000 4-runner.
Thanks!
Apco25
Old 10-22-2005 | 08:54 AM
netwt12's Avatar
its glued to the windshield, at least a little metal tab that the mirror locks onto is.
Old 10-24-2005 | 07:45 AM
Jared's Avatar
Unscrew the screws and slide the mirror off of the plate that is glued to the windshield.
Old 10-24-2005 | 09:31 AM
lee's Avatar
lee
is it windshield mounted??
my stock one wasnt. if i remember correctly, to get it out you have to do this:
first grab your flat head screwdriver, and look for the two little notches in the trim where the maplights are located. stick the flathead in and gently push up and in to loosen the plastic cover over the maplights. just be careful here because you can end up scraping the plastic trim.
once you have the cover off, find the screw that holds the entire maplight console in and unscrew it. using a minor amount of force, pull the unit out toward you. it should drop right down. you'll notice it's able to hang as is by the wiring harness.
thats from my autodimming mirror writeup...http://kidmoe.com/4runner/writeup/
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
dlotoy4runner
07-11-2002 08:24 PM
Quick Reply: How to replace rear view mirror?
