Last edit by: IB Advertising
Browse all: Exterior Guides
- Toyota 4Runner 1984-1995 How to Repair Hood Release Latch
Step by step instructions for do-it-yourself repairs
Hood release cable - adjustable?
98' 4runner - my hood will not shut correctly - it does not lock down (as matter of fact I failed NJ inspection because of it) I have to stick a screwdriver in there an pop the latch over.
I removed the hood latch assembly and degreased it but still have the problem.
I think my hood release cable may be the problem, when I pull the latch release under the dash it sticks "out" (I dont think that is right I am pretty sure it is supposed to snap closed) I guess there may be too much slack in the cable.
I see no way to adjust the slack out of the cable though?
btw i would check the latch to make sure its not rusted as well. If the latch doesn't spring back, it wont pull the cable back.
If fact, on second reading of your problem, i would suspect the latch being rusted is actually the culprit.
Yeah, I did'nt think of it that way, thanks all!
My 98 4runner has the same problem and has been like that for a couple of years. I have used tons of lube and penetrating oil on it and had some one help me keep resetting it as I worked it in, only to have it sieze up again in a couple of days. I just keep a large screwdriver beside the drivers seat now and have taught everyone in the family where to push the latch if they ever have to open it.
jasonty
41
12-23-2018 01:00 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
