FX35 bi-xenon Projector retrofit in a 3rd Gen 4Runner
Ok..so after i finished my black headlight mod, I decided to move forward with the HID conversion using the FX35 projector housing. Here is where i am at. Please give me any advise that you can offer to help me with the mod.
The FX35 Projectors w/ the one on the R side has been cut down to fit the headlight assembly better. I cut the housing with a dremel and a cutting wheel.
A picture of the washer which will support the color mod that supposedly gives a nice color to the cut-off but takes away from the sharpness. I've been told maybe this isn't the way to do it?! anyone got insight on this?
Here is the enlarged hole cut with a 2 3/4 in hole cutter.
Here is the mock-up without any mounting yet.
The shroud is off a $5 sidewalk light from Home Depot.
I am practicing on my old headlights in case i F* up the new black ones i just installed. Once i figure out the alignment issue i will put them in my new black ones. If anyone can give some feedback on how to mount them so they are level or such please let me know. THX for looking.
wait let me get this right ??
you have a 4x4
you lowered it
and its now a street queen ???
well to him his own
i would only do all that to a 2wd
but it still looks clean regardless
not bashing
just my .02
good luck with the hids though
you have a 4x4
you lowered it
well to him his own
not bashing
just my .02
Looks good. I'm looking into a bi-xenon setup as well, probably using BMW E46 projectors. I'm just totally against hacking up the wiring in my 4Runner. You're probably not going to get that much good advice on this forum on your progress. Hang out HID Planet, there you'll get some good direction.
yeah, the new headlights are a pain...
fx's are cheap, and if you didnt go oem, you could get a ballast/d2s setup for like 75 bucks from ebay. i know two people who went the ebay ballast/bulb route and they've been happy for over 2 years. ill be trying a similar path w/ the 50w setup ill be messing with.
I would consider SHONUUP's ride a Street King, not a queen, because he's obviously not a female and his ride does not look girly in any way, am I making any sense?
Hey man, I'd say that you're doing a great job. I don't have any experience w/ the FX projectors, but maybe Pfdaxe will chime in on how he did his color mod...
When working on getting a perfect horizontal alignment, I basically just aligned it the best I could, drilled the holes to mount the projector, and then I put them on my rig to test it. Then you can make some minor adjustments before tightening them down and sealing them up. Worked well for me. Just check and double check, before finishing because you WILL notice it when all is said and done.
But really, great work so far. I'd say it's pretty hard to screw it up, so just don't rush it and it'll turn out great
But yeah, HIDPlanet has loads of info and people who are more than happy to answer your questions, although if you're looking for vehicle specific info the few of us who have done retrofits here on Yotatech will be more than happy to try and help you out...
I'm just curious, why would you hack into any wiring? All you need is a harness which connects to the battery and plugs into your existing wiring... No hacking required whatsoever So just do it already! You've been talking about doing this forever
I think he means buying the cheaper aftermarket ballasts instead of using OEM ballasts; but still utilizing the D2S bulbs and projectors. That's one way to save some money on a retrofit.
Your setup is one of the nicest I've seen on a 4Runner. Did you do a DIY writeup in your thread? I'll have to search it out. I've been contemplating doing a TSX retrofit on my Prelude and an E46 bi-xenon on my 4Runner, I've just not actually gathered the materials yet.
All you need to know
https://www.yotatech.com/forums/f2/h...w-pics-133563/
http://wecool.net/home/lights/4runnerretro.htm
http://www.hidplanet.com/forums/view...er=asc&start=0
Doing the o-ring/spacer mod adds a cleaner/sharper blue cut-off.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
jerusry
10-19-2015 05:28 PM
