Last edit by: IB Advertising
Browse all: Toyota 4Runner Exterior Guides
- Toyota 4Runner 1996-2002: Why is My Frame Squeaking?
Guide to diagnose trouble and recommended solutions.
Front suspension squeak over bumps, what is it?
When I go over a bump/dip in the road I get a loud "squeak-squeak".
It doesn't happen all the time, rather only when I get a fair amount of front suspension travel- like going slow over a speed bump where you can make the front end dip quite a bit more than if you fly over one and just thump over it.
It sounds like the squeak-squeak of the spring compressing and going back.
Hope I'm being clear enough.
I want to say its the bumpstops or ?
I'm going to take it to the dealer but I wanted to know what you guys thought.
Thanks.
Thanks.
I seem to have a similar problem, but its not so much a squeak....its more of a deep creaking noise.....like "eeerk eeeek"....(im no good with onomatopeia). Seems to only come from my front right wheel.
Re: Front suspension squeak over bumps, what is it?
[QUOTE]Originally posted by FirstToy
[B]When I go over a bump/dip in the road I get a loud "squeak-squeak".
This is listed on the NHTSA website for 2003 4runners.
Make : TOYOTA Model : 4 RUNNER Year : 2003
Service Bulletin Num : SU00503 Date of Bulletin: AUG 28, 2003
Component: SUSPENSION:FRONT
Summary:
SQUEAK NOISE FROM THE LOWER FRONT AREA OF THE VEHICLE OVER SHARP IMPACT TYPE BUMPS. *TT
Should be a fix under waranty..Good luck with the dealer..
Summary:
Yeah, that sounds about right.
I am guessing it's the bumpstops or spring mount?
I made an appointment to check it out.
edit:
thanks SIl,
I'll print that out and take it with me.
edit:
thanks SIl,
i agree, grease the bump stops. i was having the same problem, if i either came into a driveway to fast or had my wheels turned to the left. got out and noticed that one of my bump stops was missing causing the sound from the driveway, and i also found that i was missing a little plastic cap on one of my steering bumpstops, not sure exactly what they're called.
Seems the prevailing opinion relates to the bump stops. However, I had the very same problem (loud, front squeaking over speed bumps and driveway entrances) and it pretty much went away when I removed the stock suspension and installed the Sway-A-Way coilovers.
It disappeared entirely when I removed the Addco sway bar and replaced the bushings with greasable ones and new endlinks.
I don't squeak no mo.
However, mine's a '99. I'd be a squeaky wheel at the dealership if I had me a purty '03 like yours!
Front stabilizer bars will squeak as well. Give the inner rubbers a shot of some lubricant like tephlon spray and see if that cures it. If it does its best to remove the inner rubbers and grease em up.
[B]Yeah, that sounds about right.
How did you make out with getting the squeak fixed???
Any updates? I'm getting a front end squeak / creak noise. It started on small bumps. Now the noise shows up with even just a slight turn of the wheel.
I tried to spray silicone lube on all the bushings and etc . It seemed to maybe just slightly help, I thought it was the rack bushings cause after spraying them the noise decreased. But it won't go away.
If anyone has any suggestions please share.
I no longer own the 'Runner, but still see Lurch around ... sold him to a neighborhood kid. Although I love my FJ Cruiser, I do miss Ol' Lurch ...
I had a squeek that i thought was the suspension too. Then after a couple years i finally figured it out....... it was the hood latch squeeking on the metal loop that keeps the hood down!?!?!?
What a releif that was!!
UPDATE: my issue turned out to be a dry joint, went to advance auto today and purchased a grease gun needle. Shot some grease into my lower ball joints, outter tire rods and upper ball joints.
noise is 100% gone.
Such a good feeling !
noise is 100% gone.
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
Yotadawgjr
10
08-23-2015 10:51 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
