Old 02-10-2016, 09:30 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Factory power steering fluid ?
Old 01-10-2009 | 04:35 PM
alotawatts's Avatar
Time for PS fluid change. The original fluid in my 2001 does not look like pink ATF. I am not doing a flush just a syphon and refill at the reservoir a few times. Best fluid match ?
Thx
Old 01-10-2009 | 05:37 PM
eric-the-red's Avatar
The manual for my 01 specifes Dexron II or III ATF. What does yours look like, maybe it's just dark after 8 years of use.
Old 01-11-2009 | 07:45 AM
97ltd4x4's Avatar
Dexron II/III ATF ...
Don't be fooled by the color Dye from the factory fill,I think Toyota does this to distinguish between power steering fluid and all there other trans fluids.
Although any synthetic dex fluid will work as well.
Old 01-11-2009 | 07:49 AM
Ron Helmuth's Avatar
should be on the cap for the power steering reservoir correct?
Old 01-11-2009 | 08:30 AM
GSGALLANT's Avatar
I recommend a flush with Dex III ATF. It's really easy. I walk you through the procedure here.
Old 01-12-2009 | 06:41 PM
marktwo's Avatar
:thumbup: I work at a local Toyota dealership in the parts department, and the factory power steering fluid is no different than the run of the mill ATF, aside from the dye color and price. A 15 oz bottle of Toyota fluid is over $40, and a waste of money. Just make absolutely sure it is Dextron III or the equivalent.
Old 06-18-2009 | 05:18 PM
stir_fry_boy's Avatar
What is the OEM color of P/S fluid?
Old 06-20-2009 | 10:34 PM
marktwo's Avatar
Same color as ATF: red as cranberry juice.
Old 06-21-2009 | 01:12 PM
cosmophonic12's Avatar
I had a PS flush about two years ago and the dealership used a clear fluid. my system has been fine since.
Old 08-27-2009 | 08:59 PM
alotawatts's Avatar
Old thread..but
2001 purcashed new - PS fluid was never pink ....honey / oil colored
Old 08-28-2009 | 01:17 PM
Thanks alotawatts, it is nice to know that I am not crazy. I changed it anyway. The dealer charges about $95. I changed it in about 20 minutes with 2 people.
jasonty
41
12-23-2018 01:00 PM
voiddweller
07-15-2015 03:56 PM
jon.r
07-11-2015 03:34 PM
Poncho0206
07-10-2015 06:21 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Factory power steering fluid ?
