ECT mod or 170 degree thermostat?
I would like to play it safe on my 1998 4runner w/supercharger and richen up my fuel/air mixture w/o any major fuel mods. I have read about a 170 degree thermostat change or putting a potentiometer in series with the ECT sensor to fool the ECU on mixture. Any advice or experience with either of these mods would be appreciated.
I'd really love a side by side post of the 170F napa thermostat and stock. I'll admit to having the 170F, and not having thought of this till after the swap. Point being: 170F will open prior to the stock 180F thermostat. But unless it allows for more flow, both thermostats when open will cool similarly. (Perhaps its a type R thermostat. HA)
That's assuming that steady state temp for our coolant is above 180F - so the thermostats aren't opening and closing frequently as we drive.
Anyways, its cheap. Might as well. Ditto cold plugs.
Of course these are both parts of the URD kit so when you get around to buying that later you'll end up with extra plugs and an extra thermostat. Or at least I did.
as always, YMMV.
(Oh, i think if you look hard you may find a 160F thermostat somewhere. That may be the TRD thermostat. But I don't think its made anymore.)
as always, YMMV.
I'd really love a side by side post of the 170F napa thermostat and stock. I'll admit to having the 170F, and not having thought of this till after the swap. Point being: 170F will open prior to the stock 180F thermostat. But unless it allows for more flow, both thermostats when open will cool similarly.)
absolutely - and there went my theory. So to the OP - try the thermostat. Nut I'm sure most here will hedge there bets and tell you that doing the full fuel kit at sea level is best. (note I wouldn't tell you that if you lived in colorado).
Your best bet as far as cheap and easy go is to do the free FMU mod. The mod will simply force the maximum amount of fuel available to the engine when in boost. My mpg dropped by 2 when I did this mod, but I still pinged and had high EGT's and dangerous AFR's.
There is simply no getting around what the stock 238cc injectors can do: very little on a SC'd 3.4.
Not trying to hijack but the OP brings up an interesting point, I never switched out my low-temp (supercharger) thermostat when I did the fuel upgrades. Anyone have any experience with reverting back to the original thermostat from the supercharged one? I can't imagine how running a little warmer would make a big difference, but again, these motors were designed and engineered to run in a very specific temp range.
If your going to run a 170F thermostat you need to avoid short trips where the engine doesn't get a chance to fully warm up.
Lower temp thermostats cause the engine to not evaporate condensation out of the oil nearly as quickly as it does with a 180F stat. Because of this if you take allot of short trips the water will never evap out and you will end up sludge and corrosion inside your engine.
If you do have to take small trips, be sure to twice a week get up on the highway and drive for 15-20 minutes so the engine can get a chance to evaporate the water and push it out via the crank case ventilation.
FOG
FOG
Longbed 90
03-11-2019 12:38 PM
LotOMiles
09-14-2015 11:45 PM
