Car making a funny noise, almost sounds like a diesel engine...
Old 07-19-2005 | 10:36 AM
UNR.Grad's Avatar
Car making a funny noise, almost sounds like a diesel engine...need advice!!!!
I left for two months and lived in Hawaii, with my car sitting in my parents driveway. They drove it about every two weeks. But when I got home the car has this rumble/knock in the engine, it almost sounds like the noises diesel engines make. Any idea what could be causing it?
TIA
Old 07-19-2005 | 10:47 AM
TRunner's Avatar
Bad gas? I would see what happens after the next tank. How is the idle?
Old 07-19-2005 | 10:50 AM
jimbo74's Avatar
check timing, if thats ok, look towards needing a valve adjustment, or a possible exhuast leak
Old 07-19-2005 | 10:55 AM
UNR.Grad's Avatar
I just put in a fresh tank of Chevron and it hasn't goen away, bu tI've only put on 20 miles with it, we'll see. Idle is fine, not rough or jumpy or anything.
Old 07-19-2005 | 10:56 AM
UNR.Grad's Avatar
How can I check timing?
89macrunner's Avatar
timing light
jimbo74's Avatar
with a timing light
Old 07-19-2005 | 11:03 AM
bob200587's Avatar
Exaust manifold gasket.....that fixed the sound what you describe on mine. just something else to check...
Old 07-20-2005 | 02:49 PM
calisurferdude2000's Avatar
Probably loose valves, same thing on my dad's Ford.
Old 07-20-2005 | 03:39 PM
4RUNR's Avatar
Guest
Revulcanize tires? Ohh right, a 2000 has radials, no distributor, no carburetor and computer controlled timing.
How hot was it 2 months ago and how hot is it now? Your oil is turning to water more than likely.
Old 07-20-2005 | 04:04 PM
callmej75's Avatar
U know...I thought mine was a diesel for a while....turned out I had loose debris flying around in my cat...eventually stopping it up. I also thought it was pinging...I adjusted timing...throttle body....still nothing.
Old 07-20-2005 | 08:24 PM
UNR.Grad's Avatar
I just did an oil change two days ago, no difference.
Old 07-20-2005 | 08:41 PM
4RUNR's Avatar
Guest
If it's 100F out, 5w-30 is a bit thin.
Old 07-21-2005 | 03:17 AM
2ToyGuy's Avatar
Yeah, with the temps we see, I use 20W50. Works great. Nice and quiet, smooth...I won't know what to do when I finally seel this place and move to Oregon or Washington... ...But I'll figure it out
Old 07-21-2005 | 11:49 AM
UNR.Grad's Avatar
I dropped it off at the dealer today and the service advisor had no idea what it was, so I'll let you as I find out.
Old 07-21-2005 | 02:27 PM
UNR.Grad's Avatar
He just called and it was the water pump failed, and it is covered under warranty. The question I have now for you guys is he says for another $228 he will replace the timing belt and the three other belts while he's in there. Isn't that a little high? The car is a 2000 with 85,000 miles. What would you do?
Old 07-21-2005 | 02:31 PM
User 051420's Avatar
Consider that the belt runs $46 at list, and there isn't that much more labor when they're done with the waterpump. Sounds like a little much to me.
Old 07-21-2005 | 02:35 PM
UNR.Grad's Avatar
How much are the other belts? Should I ask for them to do the thermostat?
Old 07-21-2005 | 02:36 PM
I got all of mine for less than $50, thats for sure.
Maybe it's not such a bad deal....
Old 07-21-2005 | 02:43 PM
964runner's Avatar
id do it
Quick Reply: Car making a funny noise, almost sounds like a diesel engine...
