Brake Warning Light Question
I have a 96 Runner with just under 200K Miles on it.. I am getting an intermittent brake warning light. The strange thing is, it only happens in the morning when I first start it. It goes on and off for the first 5 minutes or so then it goes off for the rest of the day, until the next AM...Any ideas? Thanks in advance...BTW the brake fluid resevoir is full up..
I've also had the switch in the lid of the master cylinder go bad. If the fluid is not low, you could try jumping out the wires going to the switch. If that fixes the problem then you know you've got a bad switch in the lid.
The strange part is it only does it in the morning for the first few minutes of the drive and goes away.. I have the brake resevoir filled all the way up to the max, so I can't imagine it is because of the brake fluid level..
Thanks for the replys...
From: Far western Kentucky (transplanted from central PA)
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
Johntom240
7
07-13-2015 12:18 AM
