Last edit by: IB Advertising
- Toyota Tacoma How to Install Trailer Wiring Harness<br>Step by step instructions for do-it-yourself repairs.
Brake Controller & 7-pin trailer Install 3rd Gen 4Runner
I recently installed a brake controller and wiring harness in my 1997 4Runner. I decided to take some photos and create a "How to".
Parts
Parts
Wow, what a way to make an intro here at YT! Great write up and detailed pics
Let me just add this - Be sure to seal up that hole in the firewall really good. I ran some wires like that too in my 4Runner and thought I had it sealed properly until I discovered water was leaking into the cab thru that hole when it rained. I'm sure you sealed it properly, just wanted to make sure others knew to do so.
Again, nice work
Again, nice work
FYI on the parts:
Dexter axle Predator Controller: $60.00 Shipped http://www.dexteraxle.com/predator_dx2_brake_controller
Napa
30 Amp Circuit Breaker Fuse $8.00
15' 12g Black Primary Wire $6.00
15' 12g Blue Primary Wire $6.00
12pc pack of Crimp Caps $3.00
Misc ring terminals $2.50
4 Self-tapping (Stainless or plated)screws $1.50
Pollack Trailer 7 pin connector with bracket $15.00
6' of 14ga 7-strand trailer wire $10.00
4 red wire nuts $2.00
4 zip ties $.50
Napa
4 zip ties $.50
Also you don't want the wires to chafe around the hole that was drilled. Maybe find a rubber grommet, snip it and pull the wires through and place in hole. That almost sounds a little nasty.
Nice write up! Just what I needed.
Would like to thank you for this thread - it helped me alot.
I installed my brake controller (Tekonsha Primus IQ) above the fuse panel. I couldn't get an angle I was happy with on the other side of the steering wheel. I only had to cut a little bit of plastic out with a Dremel and cutting disk. Super easy. On the left side worked out even better. I can see and reach it easily while driving. Obviously, if you have switches above the fuse panel, like an e-locker, this won't work. I was going to mount it in the fuse panel area, but the door arm got in the way.
I'd suggest using 10AWG for the black wire, tho. Just for peace of mind. After looking around at controller installs, seems like this is best practice.
Wire wasn't as hard to find and splice into as I thought. I used a crimp-splicer thingy. Made things super easy.
I put mine on the right side but it barely misses the e-brake (I have a Tacoma) and my knee. Someone with longer legs might be hitting it all the time. The one thing about a brake controller- they're always lit up. I got lucky in that a direct view of mine is blocked by the steering wheel. I need to move my head to the side to see it. Otherwise it would drive me crazy at night. I had to put electrical tape over the passenger airbag on/off indicator since it bothered me at night...
With a pickup there's less drilling into the body, which is nice. I'm pretty sure the only holes I put in my truck were for mounting the fuses. Everything else used existing holes or I just ran the wire outside the truck along the frame. The only splicing I did was into the brake light wire coming off the brake pedal.
This is n awesome write up- Thank you very much. Only one part I am confused on- the Reverse (back up lights?) wire coming off the 7 blade plug (its a purple wire on my Hopkins adapter, wired to the center pin)- where do I attach that wire? What do I splice into?
Thanks for any help
Thanks for any help
Yeah you'd need to upgrade. I mean in theory you can mickey mouse it and just run another wire for brakes, but that's almost as much work as switching to a 7 pin and a hassle.
What's your vehicle? There are probably other tutorials online. It's a lot more straightforward on pickups than 4Runners.
Gene
19
06-03-2002 07:07 PM
