Old 04-21-2016, 01:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Towing & Hauling Guides
Print Wikipost
96 4Runner Trailer Wiring
Old 05-24-2010 | 07:41 AM
Kevmo's Avatar
Hi, I have a 96 4Runner that is having issues with the Trailer wiring. Basically the lights are not working as they are supposed to. When I turn on my blinker both lights start to blink. When I turn on my driving lights, only one of the lights turns on the trailer. I have isolated it to being a problem with the vehicle and not the trailer. I have replaced the wiring harness on the back of the vehicle. I still have the issue. My guess is that it is a problem with the Tail Light Converter. Does anyone know where the Tail Light Converter is located on the 96 Toyota 4Runner and how to access it?
Thank you
Old 05-24-2010 | 07:45 AM
Elton's Avatar
its on the pass side by the little cubby space you will need to pop off that whole plastic trim though
Old 05-24-2010 | 01:45 PM
CYi5's Avatar
Hopkins plug 'n play replacement.
Instructions
Old 05-25-2010 | 06:42 AM
gpcollen1's Avatar
You replaced what harness already? All you needed to do was replace the trailer wiring harness complete with converter.
$34.95 at etrailer and it should come with instructions. Make sure you install it on the side that it says to or your blinkers will be switched.
http://www.etrailer.com/t1-1996_Toyota_4Runner.htm
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
Nickdigg
07-07-2015 06:04 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: 96 4Runner Trailer Wiring
