4WD light flashing - No 4WD
Old 02-13-2008 | 05:44 AM
ROOFGOOF's Avatar
Exclamation 4WD light flashing - No 4WD
Got a bunch of ice around here and tried using 4wd and got nothing. Just the light flashes....now all of the time.
I can't get it to go off and I am still in 2wd.
Its a 99 4Runner with 84K miles. I disconnected the batteries for alittle while thinking it was a computer issue...but it didn't help. Does it sound like the actuator ?
EDIT
Disregard, I just found some info on the search...
Thanks.
Old 02-13-2008 | 06:31 AM
mkgarrison5's Avatar
well what did you find??
Old 02-13-2008 | 07:07 AM
wjwerdna's Avatar
yep, now I'm curious, and I don't feel like searching =)
Old 02-13-2008 | 07:10 AM
X2 :-)
Old 02-13-2008 | 07:36 AM
ROOFGOOF's Avatar
from what it sounds like its either :
vacuum lines
the actuator
I just need to figure out which one it is.....hopefully I don't have to sink $$$ from a stealership.
Old 02-13-2008 | 07:39 AM
ROOFGOOF's Avatar
here are the threads I found...seems to be alot of these problems.
https://www.yotatech.com/search.php?searchid=4310147
Old 02-13-2008 | 08:38 AM
bad link bro.. no search found
Old 02-13-2008 | 09:25 AM
ROOFGOOF's Avatar
Humm, not sure why that wouldnt work, here is another.
https://www.yotatech.com/search.php?searchid=4310586
Old 02-13-2008 | 09:55 AM
cackalak han's Avatar
Still doesn't work.
You have to post the link to the post. I think you're trying to post a link to the search page.
Did you try revving your engine with the 4WD pushed in. Since it does work on a vacuum system, it helps to rev. Hope you get it figured out, though.
Old 02-13-2008 | 02:33 PM
ROOFGOOF's Avatar
Well, all I did was type " 4WD light flashing" in the search box and got a handful of results.
Doesn't appear its going to fix itself, I've tried time and time again putting it in 4wd with no luck....light is still flashing and no 4WD.
Old 02-17-2008 | 09:27 PM
DoubleZero4x4's Avatar
Lots of posts about this already. This is the thread I used to fix my problem.
https://www.yotatech.com/forums/f2/4...er-ltd-131201/
Old 07-10-2008 | 12:53 PM
ROOFGOOF's Avatar
Well, I swaped out the front actuator on the diff and still nothing.... out 40.00 .... CRAP! Any other ideas why my 4wd is not engaging?
Old 07-10-2008 | 01:13 PM
Fink's Avatar
vacuum lines
the actuator
Have you checked all of your vac lines?
Fink
Old 07-10-2008 | 01:49 PM
ROOFGOOF's Avatar
Fink
Whats the best way to check them and where are they all located? After dinner I will go underneith and look around.
If its a vac line do they usually pull out or tear causing this problem?
Old 07-10-2008 | 01:54 PM
Fink's Avatar
I had two tear on mine. For the life of me I can't remember where they were.
I've been out of the 3rd gen game for a while now.
I'd wait for some of the guru's to post up.
Sorry I couldn't be of more help.
Fink
Old 07-11-2008 | 04:36 AM
BigBallsMcFalls's Avatar
above the driver side front wheel in front is the vac tank for 4wd stuff
follow those lines to everything
Old 07-11-2008 | 04:47 AM
Fink's Avatar
Good info, let us know what you find ROOF!
Fink
Old 07-11-2008 | 08:56 AM
ROOFGOOF's Avatar
If I get a break at work this evening, I will take a peak. BTW= the ride into work today with the new MAF is a world of difference!!! I should have swapped that out 25K miles ago
The flashing 4WD light flashing on and off is pissing me off though....
Old 07-11-2008 | 09:03 AM
Fink's Avatar
Hey, at least you can cross one thing off your list right?
I'm glad that worked out, it's a good feeling when you finally figure out what was wrong and get it fixed.
It would annoy me too...
Fink
what was wrong with the MAF? didnt know they go bad
Quick Reply: 4WD light flashing - No 4WD
