83 Toyota Pickup 4x4 **SOLD**
83 Toyota Pickup 4x4. 236,000 miles. 22R, 5 speed transmission. Power steering and power brakes. Bed has been bobbed, it needs some work to be finished as you can see by the pics. The cab is virtually rust free. There is a dent in the hood on the driverside front. The whole truck could use a paint job if a guy wanted it to be finished. The tires a Dayton Timberline MT,s 31-10.50-15 on black spokes and are 80 to 90 percent tread. Recent maintainence includes front and rear end pinion seals, cap and rotor, clutch master cylinder, driverside motor mount, fresh oil change. Motor is a little tired and uses a little oil. It was about a quart low when I changed it, had about 2500 miles since last change. Does not smoke. Everything works on the truck. More pics upon request. Located in Montrose CO
$1500.00 firm. Great for putt around or good start on a crawler.
970-209-9942
970-209-9942
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
