Last edit by: IB Advertising
Browse all: Lighting Guide
- Toyota 4Runner 1984-1995 How to Replace Parking Lights with LEDs
Step by step instructions for do-it-yourself repairs
LED turn signals
LED turn signals
How did you guys get your turn signals to flash normally after replacing the regular bulbs with LEDs? I replaced my rear ones with LED bulbs, and the front ones are one-piece LEDs that I cut out and spliced into the corner lamps. After the connections were made, they just let out a constant "BEEEEEP" now; they don't even flash at all.
In an issue of Toyota Owners mag, they cut out a resistor in the flasher relay itself. The problem is I don't have that same relay, so I have no idea what to do next. I don't have turn signals at the moment.
Help?
Help?
I have only used the LED lights never the bulbs
I have the 2000 Tacoma
I replaced my stock Flasher with Napa Part # EP-35L
Not sure if that will work for what year your dealing with.
The LED lights are such a low load you need to add more resistance to the circuit.
I only had the hyper flashing never the squeal .
Maybe you have another problem.
With these LED lights the polarity is important when they are wired.
They have to have resistors, or else they will not flash properly. If the polarity is incorrect, they just won't turn on.
use one of these, and you won't have to add resistors:
https://www.google.com/search?q=vari...utf-8&oe=utf-8
"variable load flashers" are meant to be added to trucks that tow, where the resistance of the flashing lights varies every time it tows a trailer.
Those flashers just are adding more resistance to the circuit .
some people would rather spend the time adding resisters to the circuit I would rather just change a flasher.
I am not sure that is just working smart or being lazy.
Thanks, guys.
I actually ordered the flasher with the one Wyoming9 used. It worked out fine, other than having to extend the wires, as it was not a plug-in unit (I already expected that). It cost me $17.
I definitely did not want to add resistors.
Adding a resistor after you replaced your bulbs with more efficient LED's is counterproductive. Adding the resistor in parallel would increase the current load back to old level.
Getting an electronic flasher relay that would work with the new LED's is the way to go.
I found them at auto zone
I also had to extend the connections
It's weird because there is no issue when I have an incandescent bulb in...
Dennisx2
08-04-2015 01:26 PM
moonpie
07-31-2015 11:58 PM
PopsDad1
07-30-2015 02:21 PM
