General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Hella 4000s converted to HID
Old 05-08-2008 | 10:18 AM
Rock Slide's Avatar
Lightbulb Hella 4000s converted to HID
I wasn't sure where to put this thread, so I dumped it here. Mods, move it if you feel it does not belong here.
Let me start off by giving thanks to Bruce on UY for the great write up on this mod. I would have never thought to do this, had I not seen his write up first. (For more information on his install, check it out here: Click Me)
Having sold my previous set of IPFs, I was on the hunt for another pair of lights for my TJM. This time, I wanted a bigger, brighter light than I had before. I tossed around the idea of Hellas, KCs, Lightforce’s & even HID Hellas. However, once I came across Bruce’s thread, the decision was made easy.
I opted for a set of Hella 4000s I found lying around at my buddy's house he gave up on. These are 8” round, 100wt halogen lights with the Cornering Beam pattern. I chose this pattern over the Driving Beam pattern simply because I wanted a wider light spread. Of course he game them to me free of charge. The Hella wiring harness is sold separately, but since I already had an existing wiring harness from my previous lights, I was able to reuse what I already had. I also purchased an inexpensive 35wt HID kit off ebay for around $45. It is a H1 kit with 4300K bulbs.
Picture of the HID kit I purchased. Please note, this is just a universal picture of the kit I used. I used H1 bulbs.
Install was very easy. I removed the lense from the housing and simply removed the stock 100wt halogen bulb:
Next, I inserted the new HID H1 bulb:
Like Bruce, I also drilled a hole in the back of each housing to accommodate the new HID bulb. I decided to leave the stock-wiring plug in place in case I ever decide to convert these lights back to a halogen set up. Therefore, I just covered up the existing pin connections with tape and zip tied it off.
With the bulbs installed, I sealed the grommets with black RTV silcone to further prevent water from leaking in through the new holes.
I sealed each ballast to prevent water from entering. I disassembled each one and placed a bead of silicone inbetween the top and bottom covers. Once the covers were reinstalled and the silicone had dried, I wrapped each ballast in tape. I also siliconed both areas of the ballasts where the wires plug into it.
To mount them, I just zip-tied them in place. I may ditch the zip ties and upgrade to hose clamps in the future, but for now, this works.
(You will also notice I have 4 ballasts mounted…the other 2 are wired for small fog lights that I’m in the process of adding.)
Lights mounted. I also added a set of clear covers to the lights to protect the lenses:
Darkness was approaching, but here they fired up:
That night, I took a few more pictures of them:
Approx 10ft back:
Approx 40ft back: (And yes my headlights are still on. I will say that the camera deceives you a little though. In this picture, both lights are on, but it appears as though only one is. From this distance, I could clearly make out both lights even though the camera could not. Although, if I looked at them too long, I could not see anything afterwards. They are very bright):
On the trail with just my headlights on (photo taken thru the sunroof):
Same spot with just the Hellas on:
Notice the ridge in the background…that is approximately 300ft away.
I'm digging these new lights. The light output is amazing. With this Cornering Beam pattern, the light spread is almost a complete 180 degrees and reaches very far out on both sides. I could not stand back far enough to get a good enough picture to show the side-to-side light spread, but believe me, it is WIDE.
Now I can say I officially own a pair of Hella HIDs
I'll post a video soon of them warming up...it's really cool to see too.
Old 05-08-2008 | 10:45 AM
Hirox's Avatar
Awsome work!
I always admire what you done well.
It makes me to buy one for my rig
looking foward to see your video.
Old 05-08-2008 | 11:05 AM
netwt12's Avatar
good work. you did a really clean install. War Eagle BTW.
Old 05-08-2008 | 11:28 AM
blarchitect's Avatar
Cool
So bright!!
As ever, professional install!!
Tacoclimber's Avatar
Very, very cool! Great writeup!
Old 05-08-2008 | 11:35 AM
Sloan's Avatar
oh please, not that crap lol
looks awesome though, the light output looks fantastic!
Old 05-08-2008 | 11:51 AM
Rock Slide's Avatar
Thanks guys...these lights really do turn night into day.
Old 05-08-2008 | 11:59 AM
Cxrazy's Avatar
That just inspired me to do this mod.
Thank you.
Old 05-08-2008 | 03:05 PM
pattycakes77's Avatar
WOW! that looks like a train! i guess you won't have any trouble seeing where you're going and people won't have trouble seeing you
a nice, clean install as usual. it's all in the details
good job!
Old 05-08-2008 | 04:10 PM
Texas_Ace's Avatar
I have been planing to do this to my extra lights for some time, though i was going to use the Hella 500's. But i really like that beam battern of the 4000 cornering lights!
Before any of that though i need to get an SC!
Old 05-08-2008 | 06:23 PM
Rock Slide's Avatar
Crazy aint it. You look head on at these lights at night and it will cause you to loose your vision momentarily. I know, b/c it happened a few times to me...
Old 05-08-2008 | 06:36 PM
Rock Slide's Avatar
Originally Posted by Hirox
Awsome work! Looking foward to see your video.
As promised...
http://www.youtube.com/watch?v=bWfSjmDzgFo
Old 05-08-2008 | 06:45 PM
MARSHALLMAY's Avatar
I have been thinking of doing that for over a year now. The only reason I don't Is because HID bulbs burn out very quickly when they're switched on and off frequently. I'd love to have them for hi beams, and they do look awesome from the drivers seat. But that's alot of $$ for light bulbs.
Old 05-08-2008 | 07:13 PM
Cxrazy's Avatar
Originally Posted by Rock Slide
As promised...
[YOUTUBE]http://www.youtube.com/watch?v=bWfSjmDzgFo[/YOUTUBE]
Where'd you get the arc reactor?
Old 05-08-2008 | 07:35 PM
Fo_SheeZy's Avatar
Looks amazing, you should upgrade your headlights though, are they stock?
Old 05-09-2008 | 02:27 AM
Jdizzydub's Avatar
Man was tinkering with the thought of how to do that with my 500's...that totally gives me the idea. I do like the beam pattern better on those 4000's, that's just awesome! Was looking at that same kit on ebay, too.
That picture head on is super bright, and as said before looks like a frickin train,lol.
Nice work!
Old 05-09-2008 | 04:59 AM
Rock Slide's Avatar
Let me just say I'm working on an upgrade for those too
Old 05-09-2008 | 08:46 AM
Ron Helmuth's Avatar
awesome nicely done good attention to detail and weather proofing
good video and pictures
those help a lot
Old 09-01-2008 | 07:30 PM
aowRS's Avatar
Rock Slide,
Nice work - the light output seems fantastic.
I ran a set of 4000 Eurobeams for about 5 years and then removed them. They've been in a box in my shop for almost a year (thoughts of selling them crossed my mind). I may need to follow your lead and bring them back to life.
Andreas
Old 09-03-2008 | 10:54 AM
Rock Slide's Avatar
Originally Posted by aowRS
Rock Slide,
Andreas
Thanks. The Cornering Beam does a good job of spreading the light all over. I'm sure the Euro Beam would work well too.
Quick Reply: Hella 4000s converted to HID
