Sponsored by: CARiD
'04 Tacoma V6 5VZ-FE Timing belt replacement help
Old 08-14-2010 | 09:53 AM
jtrist's Avatar
I have an '04 Tacoma V6 5VZ-FE with a timing belt Is it the same procedure for removing the belt as it is for the chain in the manual? I also plan to change the pump at the same time. Anything else I need to know? Thanks!
Longtime Toyota LOVER
Old 10-29-2010 | 08:07 PM
g84-04's Avatar
tacoma 2004 belts and pumps
Just bought an 04' Tacoma TRD 4x4 V6. I need to change the belts, water pump, and what ever else I see when I'm in there. Does anyone have any suggestions on brands of the parts? What else should I order to make my truck last longer? Plan on having it for the next ten years.
Thanks.
Old 10-29-2010 | 09:52 PM
dropzone's Avatar
Fossilized
This Link to Toyota Factory Service manuals will have the procedures you need.
Advice on parts-a lot of people say to stick with factory parts.
Make you truck last longer: regular/preventive maintenance, keep your tires rotated balanced, don't abuse it...
Old 10-29-2010 | 09:55 PM
Elton's Avatar
i went by this http://www.4x4wire.com/toyota/maintenance/timing_belt/
and got this kit very good parts
http://cgi.ebay.com/ebaymotors/Timin...Q5fAccessories
Old 10-29-2010 | 10:02 PM
g84-04's Avatar
Thanks. Found a bunch of info on tacomaworld also. No one has mentioned anything about brands yet. Figured factory parts are the best if no one is complaining about them anyway.
I have an 84' and 86' also. I like working on my own vehicles because I have peace of mind that way. Having other people do the job is more money, but more importantly, I don't know exact workmanship they put into it.
Thanks again.
Old 10-30-2010 | 12:02 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
There are no "brands". B/c factory parts have the highest quality and QC.
You can get any brands at your local PepO'RileyAutoAdvanced, but take about +/- 20,000 miles off the factory advised service intervals.
No cheap-o China WP will outlast a Made in Japan to Japanese specifications, Aisin WP.
bryan34w
12
09-30-2015 02:50 PM
Sam hain
19
09-30-2015 08:25 AM
charlie_fong
09-27-2015 10:06 PM
83
09-27-2015 04:13 PM
langry345
09-14-2015 03:36 PM
Quick Reply: '04 Tacoma V6 5VZ-FE Timing belt replacement help
