Old 02-09-2016, 10:21 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Need help Seat belt buckle won't disengage!
Old 03-20-2008 | 08:21 AM
Fo by Fo's Avatar
So I have 91 4runner, and the other day I pull into my driveway when to my surprise, my seat belt buckle won't disengage when I push the button! After being trapped in my drivers seat for about 5 minuets I slither out from undereath my seat belts. When I push the button to undo my belt it just goes in and nothing happens. I tried a search but could only find info on fixing the belt retractors. Any ideas what I need to fix this? Should I just buy a new buckle/seat belt assembly? Anyone know how much they are? I'm guessing I'd have to get this part from the dealer ship or a junk yard.
Thanks guys.
Old 03-20-2008 | 08:47 AM
dirtoyboy's Avatar
I have some seatbelts for sale if you dont fix it
Old 03-20-2008 | 08:48 AM
loacyota's Avatar
At least your not still stuck in the seat
Old 03-20-2008 | 08:53 AM
MMA_Alex's Avatar
just buy a new end (the piece that it goes into). Once they break they never tend to work right. Unless something fell down there and is jamming it, and you can figure out how to get it unlatched, and the object removed.
I had a 93 explorer and had em break (wouldnt latch) so I bought one off a guy parting out a truck on a forum. He shipped both of em for $15, and I ended up selling the one i didnt need for around $100 on ebay.
Old 03-21-2008 | 10:34 AM
Fo by Fo's Avatar
I see, any idea how I get the two pieces apart since they are stuck together now?
Old 03-21-2008 | 11:11 AM
Brenjen's Avatar
Cut it off after you get a replacement? I'd say a Dremmel, a regular cut off wheel, a hacksaw...maybe even a pair of bolt cutters & a large screwdriver to pry with would get it off. Shouldn't be to difficult.
Old 03-21-2008 | 12:27 PM
MMA_Alex's Avatar
I'd unbolt it if you can, and cut it apart with a hacksaw while holding it in a vice...or you could get fancy and use the jaws of life
Old 03-21-2008 | 03:41 PM
just a 22re's Avatar
try yelling at it that seams to work for me alot. and yes i have a stuck seat belt as well all i did was spend about 2 minuts yelling and screaming at it then hit the button and wiggled it right apart thank god it yours was the front seat cause i was stuck in the back seat for over a hour untill i got it out man i hate the fact that once you got tight on them rear seat belts they dont go lose!!! but yeah try holding the button and wiggling the belt part that worked for me...
Old 03-21-2008 | 03:52 PM
rowdy235's Avatar
WD-40? I have no experience with seatbelts but thats what i'd try first.
Old 03-22-2008 | 10:09 AM
Fo by Fo's Avatar
Well I ended up fixing it, I pushed the button down and pulled out some little plastic debris in there with tweezers and blew in there real hard to try and get all the dust and junk out. Don't know if that was what fixed it, but it works now! Thanks guys
WellsR
12
07-31-2015 03:27 PM
cgilley
07-25-2015 10:55 PM
icentropy
07-09-2015 02:12 PM
garagespace
07-09-2015 08:37 AM
Quick Reply: Need help Seat belt buckle won't disengage!
