Old 03-30-2016, 11:18 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Electrical Guides
Print Wikipost
Is my starter going bad?
Old 05-02-2010 | 06:45 AM
flynn25's Avatar
sometimes when i get in my truck to start it, it just clicks, then i roll it off and turn it back off then it starts right up. or if i just sit there and turn it while it clicks it eventually starts... does this sound like a starter problem.
Old 05-02-2010 | 07:04 AM
VANCE164's Avatar
yea I'd say ur starter is going out or your battery is low make sure and have you better checked my chevy does this but thats because its not shimmed but toyotas do not need shimmed.
Old 05-02-2010 | 07:07 AM
87hillbillyoter's Avatar
yea sounds like the starter. thats exactly what mine was doin when it went bad. and dont wait to fix it cuz it will die without warning.
Old 05-02-2010 | 07:08 AM
flynn25's Avatar
alright thanks for the help guys
Old 05-02-2010 | 07:32 AM
SoCal4Running's Avatar
Most likely pitted contacts, if you can pull the starter yourself you can change them for WAY less $$$ than a starter would cost.
Old 05-02-2010 | 07:34 AM
xxxtreme22r's Avatar
x2 on the contacts and solenoid, very cheap fix if you can pull out the starter yourself.
Old 05-02-2010 | 08:28 AM
PismoJoe's Avatar
x3 on contacts and solenoid. Toyota starters don't really go bad, the connections get worn. You definitely want to go with a TOYOTA starter if you do decide to replace the unit. Check this out: http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 05-02-2010 | 09:39 AM
the starter itself is pretty easy to pull. just a couple bolts that are in some pretty tough spots, took me quite a while to get them out
Old 05-02-2010 | 10:32 AM
PismoJoe's Avatar
Yeah, you're going to be busy for a while. It helps if you drain the oil, then you can get the oil pressure sender unit out of the way so you can get an extension to reach that lower bolt. Swivel heads are your friend!
Old 05-02-2010 | 11:10 AM
Matt16's Avatar
Bingo
Replacing the whole starter would be nuts, the only problems I've *ever* heard with Nippon Denso starters (OEM for Toyota) is the contacts wearing.
EDIT: Pismo Joe already said exactly what I what I said, oops.
Old 05-02-2010 | 11:59 AM
85toy's Avatar
on a 22re it takes about 15 mins from start to finish, no need to remove anything else.
Old 05-02-2010 | 01:36 PM
Tubbyfatty's Avatar
Heres a better link with less talk and more pics lol.
https://www.yotatech.com/forums/f116...ct-fix-193101/
Good luck.
Old 05-02-2010 | 03:26 PM
Jay351's Avatar
Originally Posted by Matt16
Bingo
Note that those nippon denso starters are factory on many other cars, including the dodge caravan
gotta love a $5 starter fix!
Old 05-02-2010 | 05:09 PM
I know they are used on Subaru's, my Outback has almost the same exact starter. It uses the same contacts inside but a little longer plunger and the exterior shape is also different but definitely shares most of its parts.
Old 05-02-2010 | 07:54 PM
PismoJoe's Avatar
Haha no worries I'm glad to see other people recommend Roger's write-ups. I just pulled my starter from my 4runner (22re rebuild process) and the idle gear that makes contact with the flywheel is looking pretty warn...$8 from Toyota, you might want to see how yours looks when you pull it!
Old 07-14-2011 | 05:48 PM
awg1979's Avatar
I just did the contacts on my '95 22RE. If you can pull the starter yourself, it's a super easy fix and will save you a bunch.
Old 09-04-2011 | 12:55 PM
byGodsgrace's Avatar
thank you so much for this site, i just about made the huge mistake of replaceing the whole starter and me being the cheapskate i am i would have gone with the cheapest starter there is. on the 3 liter it takes 5 minutes to pull. 14 mil swivel with a 1.5foot extension and a impact ( or if you did it in the walmart parking lot, a drill once you loosen that bottom bolt. then 12 mil for the cable. 8 mil for the three cover bolts and 14s for the contacts. contacts were big time gone...after i pulled them i went to autozone and found out no one carries them(duh). i needed the truck so i put a washer between the contact and case and moved it forward enough that it wold make contake with plunger. works like a charm. obviously im ordering a set asap...but just an fyi to get you out of a bind...if you dont mind pulling the starter again in a week. its not that scary tho
boguspiano
12-17-2015 02:51 AM
tdsmith8
08-11-2015 10:09 AM
clok
08-01-2015 09:42 PM
ZONAYODA
07-13-2015 07:17 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Is my starter going bad?
