List of all light bulb types?
After being out of the 4Runner game for a few years, I picked up a '90 SR5 this morning. Got a wild hair to swap all the bulbs except the headlights for LEDs. Is there a comprehensive list of what bulbs go where that I can use while shopping for the replacements? I did a few quick searches on my phone, but didn't see anything.
Thanks!
Thanks!
Where are you guys planning on sourcing lights? Have you heard of fasttech.com prices are much cheaper than other sources I've seen.A guy at work told me about them, he has ordered a mod for his e-cigarette from them and was very pleased.
I plan on swapping out bulbs also. Found a bulb for dome light at walmart $6 bucks kinda let down. The 2 little LEDs that make up the bulb just don't seem to put out much light. That site has a couple other options that fit into internal light fixtures I might try later after holidays.
superbrightleds has a search tool that tells you what size bulbs to get for exterior brake, turn, licinse and back up lights. Get the bulb color that corresponds with the lens color: red for brake etc. (Duh, I guess) I spent last night searching threads and can't figure out exactly how many of which bulbs to order for the SR5 dash. I want to do clear in my 89. I got a bunch of 6 or 8 LED torpedo bulbs off eBay for about $6 and changed them in the '89 and the 2000 4Runners. The same size fit all the interior ceiling lights but don't fit the 2000 map lights. I think the dash needs 194 and 74 bulbs but I'm not sure how many. Can anyone comment on how many to get? Manual, 22RE,SR5 swap.
I just did mine..
I repalced the Taillights with
http://www.ebay.com/itm/191338519129?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITIt had a regular 1156 reverse light bulb so I bought an 1156 LED from Wal-Mart to replace it
They work very well reverse lites are nice and bright and they look good too...
I wanted Daytime Running Lights so I replaced the 2 wire Bumper Lights with
http://www.ebay.com/itm/160911768879?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITand
http://www.ebay.com/itm/331207817337?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITwith
http://www.ebay.com/itm/371160302493?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITSo they come on with the engine and turn off when the headlights come on..
I replaced the headlights with
http://www.ebay.com/itm/181516663859?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITand they looked tuff, and everybody liked them but in a couple days the pass side had melted the plug which I replaced and a few days later they started doing some weird and I ended taking them out and smashing them so I didnt put them back in eventually..
That pretty much covers it except I havent done the side lights but they are T-10s
Bumper Lights 1156 - Tail/Brake Lights 1157 - Reverse Lites 1156 - Corner Lights - T-10
No, I dont work for e-bay...
Otherwise ya gotta use the resistors which get very hot so mount them to metal.
You can also modify the stock blinker relay by thinning out the metal thing inside it with a dremmel to raise the resistance if you are super cheap and have a dremmel..
If you dont do any of these things the stock blinker relay will read the lower voltage draw from the LEDs as a burnt out bulb and you will have hyperflash and if you use switchbacks they wont work properly..
You can get around using Resisters by getting a electronic blinker relay for LEDs.. just make sure if you do not have all LEDs that the relay you get can handle both types of bulbs..
Dumb question, but where is it, in the fuse box? I haven't got out and looked yet.
https://www.superbrightleds.com/more...c-flasher/782/
I ordered a flasher module to combat the low resistance of the LEDs. Guy said it worked for his '94 Yota pickup, so hopefully it'll be good on my '90 4Runner.
yep...
4Runner
Toyota 4Runner
First generation (1984–1989)
(1984, 1985, 1986, 1987, 1988, 1989)
High & low beam headlight H6054
Parking light 194
Front turn signal 1073
Rear turn signal 1073
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
Front sidemarker 194
Second generation (1989–1995)
(1990, 1991)
Parking light 168
Front turn signal 1156
Rear turn signal 1156
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
Front sidemarker 168
Instrument-general 194
(1992)
High & low beam headlight 9004
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
Step/Courtesy light DE3175
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
High mount stop light 921
License plate 168
Back up light 921
Glove box 74
Map light DE3022
Step/Courtesy light DE3021
Step/Courtesy light DE3022
Trunk/Cargo area DE3175
4Runner
Toyota 4Runner
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
(1990, 1991)
Parking light 168
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
(1992)
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
License plate 168
Back up light 921
Glove box 74
Map light DE3022
Toyota 4Runner
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
(1990, 1991)
Parking light 168
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
(1992)
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
License plate 168
Back up light 921
Glove box 74
Map light DE3022
4Runner
Toyota 4Runner
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
(1990, 1991)
Parking light 168
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
(1992)
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
License plate 168
Back up light 921
Glove box 74
Map light DE3022
Toyota 4Runner
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
(1990, 1991)
Parking light 168
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
(1992)
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1156
(1993, 1994, 1995)
Parking light 168
Tail light 1157
Stop light 1157
License plate 168
Back up light 921
Glove box 74
Map light DE3022
also maybe try pfanleds -- pfran was/is a forum member at ih8mud who started doing group buys on LEDs direct sourced from China. Now he's got a business and does other vehicles than landcruisers now. I've got some from him for my cruiser and damn they're almost too bright.
