How difficult to change leaf springs
Old 06-27-2006 | 01:03 PM
ReneB64's Avatar
How difficult is it to change the leaf springs on a 1993 toyota 4x4 ext cab? Am considering OME 18 and was thinking of doing it myself.....
Old 06-27-2006 | 01:23 PM
BeaterToyota's Avatar
In theory it's super easy:
1) Jack up truck by the frame and support it so the suspension drops all the way down.
2) Remove u-bolts
3) Remove shackle bolts and spring hanger bolts.
4) Installation is the reverse.
In practice, it's usually a lot harder because the bolts tend to seize up with the sleeves that are inside the bushings, and a lot of times they have to be cut out. Also, old rusty u-bolts can be a pain, so just buy new ones and cut the old ones off instead of trying to reuse them.
Since you're in CA you may not have any problems with this stuff, but I've only wrenched on east coast rigs and the rust sucks.
Old 06-27-2006 | 01:24 PM
snap-on's Avatar
you jack the truck up... support it, put the jack under the axle, then undo a few bolts and your good to go.
rust will complicate matters but really no big deal. I did mine by myself in about 1.5 hrs.
Old 06-27-2006 | 03:44 PM
kyle_22r's Avatar
the worst part is always getting the spring pins out. the shackles aren't so bad, but the pins for the front hanger are almost always stuck to the bushing.
ReneB64's Avatar
Thanks, am willing to give it a shot...will let you know how it went.
Flying91
45
04-11-2024 04:39 PM
shisha1999
09-21-2015 08:22 PM
_Nicco_
08-28-2015 07:26 PM
88sasturbotoy
08-11-2015 01:56 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: How difficult to change leaf springs
