...In-cab Fuse Panel...
Old 03-15-2007 | 05:30 AM
CanTheWhales's Avatar
Question ...In-cab Fuse Panel...
So, I'm planning out my set-up for my future wiring project (lights, CB, stereo, winch) and ran across the idea of using the fuse box that's inside the cab behind the driver's side kick panel, here's my question: the diagram on the lid is set-up in a 3x3 grid displaying 9 slots, but the panel itself is 3x4 with 12 slots...does anyone have a better diagram for a 1896 pick-up? Thanks...
Old 03-15-2007 | 05:49 AM
amgraham's Avatar
Umm, I'm not sure what you're asking but I mounted a fuse box there too. I got on of the 6 circuit ones from Advance and mounted it to that flat spot right behind the kick panel (plenty of room there) then just ran a wire from the battery to the fuse box. If you want them to just be on with the ignition run a relay.
Old 03-15-2007 | 06:35 AM
I know that, I have one actually, I was just curious if anyone has a wiring digram for the factory one because as I stated, the label on the cover doesn't have them all marked...
Old 07-28-2007 | 04:47 PM
MHale's Avatar
if you haven't found one yet, search for 86-88 fuse diagram and there's a pic of one
Old 07-28-2007 | 05:39 PM
linuxrunner's Avatar
I mounted my aux fuse block in the pass kick pannel with the ecu, seems to work good so far, bought an 8 fuse block and i have used all 8 already
and 8 was as big as i could fit with the ecu so i may have to relocate.
Old 07-30-2007 | 05:57 AM
jht3's Avatar
the kick panel box, as well as as the one under the hood, both have unused fuses. you could add hot leads and grounds to fill it out. or just add an external box like the others have done
depends on if you want them constant +12, acc +12, or ignition +12.
Old 07-30-2007 | 06:20 AM
Corey's Avatar
Co-Founder/Administrator
Staff
If you decide to go with an aftermarket aux. fusebox, the Blue Sea one is a good one.
It has both power and ground hookups on it.
Near the bottom of my 2nd page of mods is my installation.
http://www.pnw4runners.com/fjc/mods/modindex2.htm
Old 07-30-2007 | 06:28 AM
rdlsz24's Avatar
Rob
Old 07-30-2007 | 07:10 AM
frodin1's Avatar
Bluesea systems do make nice boxes. However I think at $40-$50 bucks, you can spend $15 more and get the Painless 70207 setup. They are nice because they come with everything you need. Fuses, wiring, relay etc. It all depends on what your needs are.
RyanJ989
11
04-07-2021 09:41 AM
Scotttekoch
09-28-2015 10:30 PM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
Gone Fission
09-04-2015 12:18 PM
Quick Reply: ...In-cab Fuse Panel...
