2nd gen 4runners lift guide
#441
This is my 2nd Gen
4" Skyjacker IFS bracket lift
1.5" 4crawler BJ Spacers
3" 4crawler Body lift kit
1" Lifted Land Cruiser Coils
Skyjacker 4" Extended Shocks all round
Set on 35" Mickey Thompsons
So all up about 8" over standard
I actually had brand new 33s but took them back and swapped them for 35s after i lifted it. so now i need diff gears
The following users liked this post:
jeff77 (03-03-2020)
#442
#443
91 Runner on tough country Lift
heres my runner GOLDRUSH haha. shes sittin on 35x12.5 hankooks with a tough country 4-5 inch lift with a little bit of torsion bars to get the sag in the rear on the landcruiser coils. she clears the 35s with barely any rub, even when im almost maxed out.
jeff77 (03-03-2020)
#444
This is my 2nd Gen
#445
Hi guys I need some advice on a mild lift..
I haul a lot of gear in the back of my runner including a dirtbike on a carrier hitch, generally about 500lbs or so. I don't want to lift the front, or crank the t bar or space the BJ anything like that. All I want to do is swap shocks front and rear for better ride on the highway, and lift the rear really minor like 0.5" to 1" so the truck rides level with all the weight in the back. What is the best option to do?
#446
Well I like the LC coils I'm running but that'll get you round 3 or so from stock. I'm running with the LC coils and no spacers in the front yet (I know I know I've had them for a year and still not installed...) It's a bit raked but the ride isn't all that bad.
#447
I'm about to make purchase the shocks for my LC/BJ lift, will these shocks work?
Front - Skyjacker H7052
Extended Length (in) 15.690 in.
Collapsed Length (in) 10.020 in.
Rear - Skyjacker H7024
Extended Length (in) 24.750 in.
Collapsed Length (in) 14.540 in.
I tried the search but couldn`t find anything, any input would be greatly appreciated...just want to lift my truck! LOL!
#448
#455
Go the .75.… the 2" along with the 3 - 4 " u will gain from lc coils will be too much for the angle of the trailing arms. I used lc coils that were 1" taller and I had to space the back of my fuel tank about 15mm to clear the upper trailing arm on the right hand side.
#456
It's actually pretty stable even at speeds. I was expecting it to be a bit scary but I barely had to adjust my driving style. I'm running it without a rear sway bar at the moment and that is definitely noticeable in the corners. Still…not bad thought
#457
excuse me if this might be a repeated/dumb question....but are the short sided and long sided springs referring to the number of wraps? IE 7 would be short and 8 would be long. And do all the 80 have same number of wraps on pairs? rear 7 wrap front 8s? Hope this isnt confusing..thanks in advance.
#458
Right on just looking at it I would imagine a lot of body roll but if that's not the case then wow! Like I said its a great looking truck!
