Old 03-11-2016, 03:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
22re starter nut size
Old 08-12-2009 | 01:27 PM
olharleyman's Avatar
Please HELP I lost the nut that go's on the starter stud can anyone tell me the size so I can go buy a new one.
Old 08-12-2009 | 02:09 PM
TORTIS's Avatar
Have you tried the dealer?
Old 08-12-2009 | 02:14 PM
Yea they say they only have part numbers and it will take a week to get one if I order it today
Old 08-12-2009 | 02:31 PM
93YotaGuy's Avatar
Just go to a hardware store and pick up some bolts that you can fit a nut around.
I lost mine a while ago and this has worked out great for me.
Use some lock washers and you'll be good to go!
Old 08-12-2009 | 02:33 PM
4Crawler's Avatar
Probably M10x1.25 if the stud it fits on is about 3/8" in diameter.
Old 01-05-2011 | 10:34 AM
skrape's Avatar
Mine went walkabout so I ordered a new one from my local Yota-monger.
Here are the actual specs:
The Toyota part number is 90179-10132
Price was $1.68
It is indeed an M10x1.25 flare nut, taking a 15mm wrench.
The one they gave me is black-chromed.
Here's a link to a site with a pic of a similar nut, for those visually-oriented:
http://www.amazon.com/M10-1-25-JIS-F.../dp/B001924SLA
Old 01-05-2011 | 11:48 AM
xxxtreme22r's Avatar
You know your gonna find that nut once you find out what size it is and replace it right?
At least that is usually what happens to me when I loose stuff like that.
Old 01-05-2011 | 12:52 PM
wyoming9's Avatar
Red face
I hope it was a typo but that is a flange nut not a flare nut.
Yes it is a M10x1.25 nut I buy them by the box from Pointe Products
when you work on these it is nice to have new hardware .
Because I lose this stuff all the time
Old 01-05-2011 | 12:53 PM
PETDOC's Avatar
I just replaced the starter on my '88 4runner with the 22RE engine. That nut took a 14 mm socket; same size as the bolt.
Old 01-05-2011 | 02:15 PM
pinoaktwh's Avatar
Umm, what size is the bolt? Purely a random question,,,just curious
Not that i have lost mine or anything.
Old 01-06-2011 | 12:02 AM
wyoming9's Avatar
Red face
I did measure just so I was sure to have them M10x1.25 x40mm or it could be 45mm but it was one of those lengths
Old 01-06-2011 | 06:55 AM
scope103's Avatar
The size of the wrench doesn't tell you much. I suspect that the distributors selling "hardware store" nuts and bolts want to have a little more meat than really necessary, so I have found that I often have to step up one wrench size. The 8mm Toyota bolt that takes a 12mm wrench ends up being replaced with an 8mm bolt that takes a 13mm wrench.
Annoying (I'd like to think I only need a 10, 12, 14 and 17mm wrench to work on my truck), but c'est la vie.
kgcwb44
01-29-2023 10:02 AM
Whatever123
09-30-2015 12:12 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Hiluxtrucha
07-22-2015 10:00 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: 22re starter nut size
