Last edit by: IB Advertising
Browse all: Electrical Guides
- Toyota 4Runner 1984-1995 How to Replace Battery
Step by step instructions for do-it-yourself repairs
22re ground wire locations - the guide!!!
Alright, the question has came up SO many times, so here's the final answer
I don't think I could make this any more simple
This wire comes right off the - terminal of the battery, and follows the + wire leading to the starter. It splits out of that harness right by the upper control arm and runs over to the engine block. On AC equipped models (as shown) this wire bolts to the AC compressor mounting bracket via one of the bolts that bolt it to the block. Without AC, I can only assume that the wire bolts directly to the block itself.
This wire is bundled in the wiring harness for the alternator. It splits off from the harness and runs up to a bolt at the rear of the power steering pump that mounts the pump to its bracket.
This ground goes DRECTLY from the cylinder head (bolts to the head using the same bolt as the engine hoist hook does), and runs right to the firewall.
This is probably the most commonly overlooked and asked about ground on the 22re. It sprouts off of the same wiring harness that runs between the upper and lower intake and has all the fuel injectors and VCV pigtails as well. It is actually 2 wires, that both bolt together at a bolt that secures the upper and lower intake together.
Hope that will help some folks out
The following 2 users liked this post by iamsuperbleeder:
86dolphino (09-23-2021),
Shawn Kelly (06-18-2020)
awesome, thanx man. great pictures. thanx for taking the time and pictures.
i have all of those grounds hooked up, except for #3. i wonder if i should hook it up. lol
oh and if you dont have #4 hooked up, you will get a constant check engine light, at least i did. lol.
#EDIT# sticky anyone??
The following users liked this post:
rlw0766 (03-19-2019)
I'm glad this post has helped so many people out already! I figured it would
Thanks for all the positive feedback!
lmao, yeah the motor was pretty dirty during the tare-down when I took all the pics the first pic is the completed motor though
and yeah, I got mad skillz in Microsoft Paint!
Thanks again guys! Glad I could contribute!
Travis
Travis
rlw0766 (03-19-2019),
Sorry, sorry, I forgot about the first pic Trav!
You should have shown your brake booster in the other pics though, would have made that bastard look oh so shiny and clean!!
It stands out a little too much in the pristine engine bay.
well good, I'm glad my assumption was right, lol
thanks!
I see. I'll check that out tomorrow. Thanks for the thread Bleeder
