Old 02-09-2016, 10:26 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Rear Window Won't Work
Old 01-03-2010 | 03:22 PM
1990arizona4runner's Avatar
1984 4Runner. My rear window won't go up or down and whenever I push the switch this grey box located inside of my backseat panel makes a clicking sound (attached picture). I checked the fuses, wiring, and that switch that is pushed down by the top but nothing seems to be wrong. Any suggestions?
Old 01-03-2010 | 03:52 PM
myyota's Avatar
Are all of the bolts in the top ?, there is a safty switch on the left side about 3 or 4 bolts back from the front, if the bolt is missing the window won`t work. You can also directly wire the rear window motor to a 12 volt source to see if its good.
Old 01-03-2010 | 06:26 PM
4runnerx3's Avatar
Make sure the tail gate is closed/latched all the way. If one side isn't closed all the way it will break the circuit. Make sure the wiper are is at the top position.
Old 01-03-2010 | 08:50 PM
Milkbubbles's Avatar
i have they same issue with a 1991 toy 4 runner...can anyone help..
Old 01-04-2010 | 03:06 PM
Yeah, all the bolts are on the top; especially the one that pushes the button down. Still nowhere with the problem though.
Old 01-04-2010 | 03:19 PM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/CheapTri...leshootingTips
Clicking relay indicates relay coil is actuating (from switch input), but contacts are not passing current to the motor.
Old 01-04-2010 | 06:26 PM
Coopie's Avatar
move the rear window wiper above the little stopper thing and see if it works then. i had the same problem. it was just because the truck thought the wiper was down on the window.
voiddweller
19
05-02-2016 09:10 PM
Cesarl74
04-23-2016 06:07 PM
cchinny
06-25-2015 08:11 PM
Corey
06-19-2002 11:06 AM
Quick Reply: Rear Window Won't Work
