Do they make shift kits for Toyota trannys?
Old Nov 16, 2006 | 09:10 PM
tom_mag's Avatar
I have 154,000 miles on my 2000 2.7L auto runner. It is starting to shift a little sloppy when stuck in traffic, and when doing three point turns. Is their anything I can do to make it shift a little firmer? On old American cars you can get a kit for 25 bucks, drill out a hole and install it between the valve body and you can get anything from slightly firmer to tire barking shifts. Is their anything like that for our Toyotas? Can it be done with line pressure or a computer chip?
Old Nov 16, 2006 | 09:32 PM
paddlenbike's Avatar
URD makes them.
Has anyone tried using one yet?
Here is the link.
Old Nov 16, 2006 | 09:47 PM
cheap sunglasses's Avatar
That URD product is a short throw shifter for manual transmissions. Completely different thing despite the similar name. I have heard good reviews of it though, paddlenbike. Try searching TTORA.
tom_mag I hate to say it but I doubt you will find anything. Not saying you won't but I have never heard of a valvebody kit or chip for a toyota, even the newer ones. Companies like B&M focus on domestic vehicles, although in the future they wont be able to ignore imports, with the direction the auto industry seems to be headed.
Old Nov 16, 2006 | 09:54 PM
Sorry, I completely missed the auto part. It has been a long day...
Old Nov 16, 2006 | 11:50 PM
91TPU's Avatar
change your fluid, other then that there is really not much, not to sound like an jerk but you bought an auto, and autos get sloppy after they gain mileage. sorry man
Old Nov 17, 2006 | 03:17 AM
bamachem's Avatar
you can get your valve body modified at IPT for about $600 and it will clean up the shifts. however, it sounds to me like you need a good flush and some fresh fluid.
Old Nov 17, 2006 | 09:15 AM
desertyota's Avatar
There was some company offering something for this. Had a kit that would allow you to control the shifting and lock up the torque converter stuff like that. I'll see if I can find it again.
Old Nov 17, 2006 | 10:13 AM
97Limited's Avatar
Doesn't "Level 10" make A kit for the Auto Tranny???
http://www.levelten.com/store/import...ges/toyota.htm
Old Nov 17, 2006 | 10:26 AM
SteelHound's Avatar
Seafoam Trans will clean it up
Old Nov 17, 2006 | 12:21 PM
desertyota's Avatar
Linky no worky
Old Nov 17, 2006 | 12:58 PM
JHRRLD's Avatar
http://www.importperformancetrans.com/toyotaauto.shtml
Look for valve body on this page. IPT is the best.
Old Nov 17, 2006 | 12:59 PM
Ironmike4x4's Avatar
Talk to Mark, midiwall a PM and he can probably give you more details. He's more performance oriented but I'm sure he can tell you about it.
Old Nov 23, 2006 | 08:18 AM
tom_mag's Avatar
Thanks for the info guys. I noticed that I had somehow turned off the ECT power button on my tranny and that was the biggest part of the problem.
I'll change the fluid again just to be on the safe side.
Old Nov 23, 2006 | 08:32 AM
881stGenRunner's Avatar
https://www.yotatech.com/forums/f2/new-product-announcement-manual-control-your-automatic-transmission-89502/
Here is the thread that one of yall mentioned about being able to manually control each shift, but without having to use a clutch. It is really pretty cool.
Old Dec 10, 2006 | 04:18 PM
Jim McNabb's Avatar
Level 10 & IPT offer the same service, modifying the valve body, the only difference is the price. Level 10 advertises $ 700. while IPT says $ 525.
Shipping is extra. They are both in New Jersey.
You have to remove the valve body yourself & send it off for the service which takes about a week.
I can't believe they are the only two in the entire country that can perform this service. It would be nice to find someone out west !! Oh well.....
Old Dec 10, 2006 | 04:30 PM
MTL_4runner's Avatar
I think John over at IPT used to work for Level 10......which makes sense why they are both in NJ.
Old Dec 10, 2006 | 05:09 PM
toyota_mdt_tech's Avatar
Wont be such an animal. Back in the old hydralically operated trannies, you could toss out check balls, drill large holes int ehj separator plate and toss out a bunch of accumulator springs. But now days, shifts are all electrocnially controlled. But there is no reason why one couldnt figure out how to reprogram the ECU's. Some computer nerd should be able to do it.
Old Dec 10, 2006 | 06:29 PM
jusfloorit's Avatar
You also mentioned that it is shifting sloppy while in traffic. Might I recommend a trans cooler? Any bigger tire is gonna put stress on the trans, especially the converter. The converter uses fluid to create stall and in doing so it heats up the fluid. A cooler will keep temps down and she should shift like when you first start her up, all the time. Good luck.
Old Dec 12, 2006 | 10:10 AM
toy4crawlin's Avatar
Did some research
R150 trans is in my 92 4Runner 4x4 and also the 95-2004 tacoma
so you can get a great deal on a B&M Short Shifter on EBAY
Ri
Old Dec 12, 2006 | 10:18 AM
This is how people have been upgrading the trannys for some time now.
http://www.gadgetonline.com/Transmis...tm#Prevention:
Here's where John from IPT talked about what was in the "valvebody upgrade":
https://www.yotatech.com/forums/f2/whats-valve-body-upgrade-27512/
Writeup of the removal/install with pics:
http://members.cox.net/mgriese5/Level10.html
As a Toyota Tech I'd be interested to hear your thoughts on this because they are clearly not doing any ECU programming. They have a few fancy names for the service like "hydrobalancing" or whatnot, but they are obviously mechanically changing fluid passages (along with a new set of springs......may add/remove checkballs too, not sure) since all you need to do is send them your valve body. Hard to get any info on what exactly is being done technically because they are trying to protect their business interests (no surprise there). Too bad no one ever took a highres photo of the valvebody (fluid passage side) before/after so you could see what was changed. It seems this service works similarly on many of the import vehicles, all of which are computer controlled now.
