Throttle Body Cleaning - 3rd Gen 4Runner
Throttle Body Cleaning - 3rd Gen 4Runner (3.4L V6)
By HaveBlue
HaveBlue shows you how to clean the throttle body on the 3.4 V6. This often will yield better mileage and acceleration.
Tools Required:
Throttle body cleaner (Do not use carburetor cleaner)
Rags
Long screwdriver or dowel
Toothbrush
1. First separate the intake tube from the throttle body assembly.
2. Place a rag under the throttle body to catch the run-off from the cleaning fluid.
3. Open the butterfly and liberally spray the inside of the throttle body with cleaner. A helper can be handy to hold the butterfly open while you spray everything.
4. Use a rag and a long screwdriver or dowel to scrub the wall of the throttle body. Again, a handy helper can hold the butterfly open while you do this.
5. Use a toothbrush to get to hard to reach places like the butterfly pivot.
When the inside is clean and free of gunk, reattach the intake tube and start the engine. The engine may not fire immediately or may stumble for a moment. This is normal.
You should notice your engine now has a little more power and exhibits better throttle response. Gas mileage will improve slightly as well. *Note: When cleaning the throttle body, some choose to remove it from the intake plenum. I do not feel this is necessary.
By HaveBlue
Tools Required:
Rags
Toothbrush
RedRunner_87
84
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Avenged
Jul 9, 2015 07:55 AM
